Hey all, im trying to find a solution to my misfire problem.
My car is an auto series one with exhaust, bov, DC transmission cooler, bigger side mount cooler and a uni chip. Yesterday i changed all filters, oil, plugs and installed a set of splitfire coils.
It seems to have improoved slightly since the service.
It only misses at full temp when changing up gears. :)
When i had the car in Tassie there was no 98 ron and it missed terribly under any load using 95 ron.
I uninstalled the uni chip and it stopped the missfire almost completely.
When i moved to melbourne i re installed the uni chip and it ran as good on 98 ron as it did without the unichip on 95.
This now is the best it has run with new plugs and coils but im wondering if i can get it better by ditching the unichip and go the full glove box piggyback option, or does it just need to be taken to a uni chip shop to get looked at or adjusted??
Welcome any comments, Cheers Kris
https://www.sau.com.au/forums/topic/135842-misfire/
Well if you didnt have the splitfires I wouldve said it was definatly the coil packs, as lots of RB's seem to have this missfire issue with the stocker coil packs, but splitfires _shouldve_ fixed the loss of spark issue, but then again it is only when you are running more boost and you have not listed any type of boost controller so I am assuming you are running stock boost, if so then you shouldnt have any missfire issues.....? Is the unichip adjustable?
https://www.sau.com.au/forums/topic/135842-misfire/#findComment-2525213
My bet was the coil packs too after reading how many have had a missfire problem,
So i was pretty annoyed when the splitfires didnt fix it.
There is a boost controller plug-in attachment into the uni chip.
My boost guage only shows 0.6bar which is pretty low.
That is with the unichip in, but it was much slower with the unichip disconnected
I think i will have to get hold of a boost controller
Edited by wagon
https://www.sau.com.au/forums/topic/135842-misfire/#findComment-2526027
My wifes car experienced the same problem on a trip just recently, then I found out she had normal 91ron crap in. Man did she cop a spray. We have splitfires and .8mm gap iridiums and no more problems.
https://www.sau.com.au/forums/topic/135842-misfire/#findComment-2528825
Pulled the carpet up 2day and had a look at the ECU and the unichip was plugged in but a couple of wires were not connected.
Must have been off with the fairies when i thought i hooked it up. :dry:
Connected the remaining wires and it wouldn't start, turn over but not fire. :ninja:
Unplug the unichip with the wires still connected and it would start.
Does anyone by any chance have a unichip stagea wiring diagram/wire colour list??? :D
Slim chance but will try.
Will get my tax back soon and take it for a dyno run and get the unichip wired in properly.
Still missing but its not a spark/ ignite problem.
and its not as bad now, just bearable with the splitfires
https://www.sau.com.au/forums/topic/135842-misfire/#findComment-2564673
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
