hey pretty new to this turbo stuff
ive just purchased a s13 silvia $1500 with rego!!
and just brought 1995 series (1.5 i think they said??) series 1 panels but series 2 engine? rb25det auto front for the conversion
i want to get about 300rwkw
i want to do this as safe as possible and cheap as possible i dont particuly want to rebuild the engine,
but will do cams and stuff if that is what is reccomended.
so just want to know what you guys reccomend
1. ecu as i have heard power fc no good for auto /boost controller or any other electrical item ill need?
2. modifications to auto box?
3. turbo, manifold, waste gate, dump pipe, screamer.
4. exhaust system,
5. intercooler
6. engine like parts inside ect cams, valve spring anything else
7. fuel pump, injecters.
just want to know what to get and what to stay away from like ive heard ebay manifolds not to bad but turbos r shit?
and a price would help as well has where there best price is available from ect sponser on here or of another website or just ebay ect
thanks for your help in advance
and if it was a $1500 silvia, all the money that it will take to get the car tidy.
just wondering, was the car registered? or was it uncomplied? if it was uncomplied and you are planning on registering it, you may want to sell the car and start over.
what auto box is it? the r33 one?
if so its electronic which will mean most ecu's aren't suitable as they are manual only ecu's
yes to run the std auto box. as the car is quater mile warrior only and driven on weekends
he means 'most ecu's aren't suitable'.
and i hope you have a healthy bank balance, and really really good tyres.
bank acc average want to get away for about $7,000
goodluck with it, i think u'll need around 15k to achieve that, depending who does the work etc.
ill do the work my self but there will be some work that ill have to get others to do like tuning and fitting the ecu i hate wiring
Whats the budget?
about $7,000 on engine cause the car cost me $1500 + half cut + s15 seats + R33 front n rear brakes setup and hubs, xr6 turbo wheels, s14 controll arm $3600
so then so far car owes me $5,100
want it finished for $15,000
Hold on, you bought an S13 for $1500? What sort of condition is it in? Got pics by any chance?
Cheers
+ The money for suspension & braking
ive allowed for $1000 for new suspension ive got std r33 brakes already, i just want to know will the std drive shaft handle it or should i get a r32 gtr rear cradle for the diff center and drive shaft as they are bigger stronger items?
car has one dint on it!!
car is registered until nov, its complied! when i brought it was ca18de auto with bottom end knock.
there is no way you could get 300rwkw for $7500. Computer, injectors, fuel pump, turbo, manifold, tune, exhaust, intercooler. And that isn't even including putting the motor in. Are you putting the motor in yourself? cause if your not you are going to pay quite a bit to get the motor in wired and running. if you are getting someone to put the motor and do the 5 stud conversion i would atleast budget 5 grand cause you are going to need custom tailshaft, custom gearbox crossmember, exhasut front mout. So that leaves you $2,500 which will get you a computer injectors and fuel pump. That will give you around the 180-190rwkw with an auto.
^^ agreed.
Absolutely no chance 300rwkw with 7.5k
ECU/Tuned - $1500
Dump/Exhaust - $1000
Injectors - $900
AFM - $300
Fuel pump - $250
Turbo - $2000
Manifold (not essential) - $1500
I/C + piping etc - $900
Cams (might be needed) - $900
Clutch - $1200
Diff - $800
$8650 - excluding cams/manifold, which is then $11,250
And thats NOT including the rebuild when the motor pops, which it will sooner or later so you need to allocate - $7000
Total including a motor - $18,2500 with everything, and thats just the motor and a couple of drivetrain bits...
If you set the goal to 250rwkw, you wont need a rebuild, but its still gonna cost you more than your budget is gonna allow.
And thats not including the auto rebuild, trans coolers etc etc which is gonna top out another 2-3k
I think you really should have investigated the costs of things before aiming for the sky :happy:
Performance, let alone 300rwkw... costs money dude
or for $5000 i know where there is a 12 second car. people at jamboree would've seen it. blue sigma with a stock sr20 in it (with a slightly shagged turbo). it ran a 12.9. it has run a 12.56. and there is plently left in it as its still on the stock turbo (at 15psi)
4. exhaust system,
5. intercooler
if this car is for drag use forget moddin the skyline auto box just go ti the wreakers and buy a trimatic and get it built up (as u can get bellhousings to suit rb engines ) than u can run what ever ecu u like
and i hope u got deep pockets to do this type of conversion as i do rb conversions into silvias i know what u have to do to get the motor in but as its only goin to be a drag car u dont have to worry about transport rules just andra rules
agreed, go the vl turbo auto box. jatco 3 speed im pretty sure
its a mech box so no need to worry about what ecu to use
sorry u gettin confused the trimatic is found in the vb-vk commodore geminis etc but u can buy a bellhousing to suit the rb range go full manual valve body etc
vl box has a ecu
