i put 6*9's in my rear because i didnt have the cash at the time to buy different speakers. However I am very impressed/satisfied with the sound they produce.
"cutting the parcel shelf is illegal dont do it",....hahahah so are most of the performance mods.hahahahaha
if your are going to cut your shelf, be warned its a bit of a job have plenty of band aids on hand ready.
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-290816
6x9's fit quite well in the rear if u put em at the angle like elbee said, the rear parcel shelf is easy to get out, the lack of space in the back seat however gets annoying, make sure u have like a fan cos it gets HOT and sweaty. zRemove the back seat (easy to do) the just unclip the rear shelf. too easy
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-302585
  • 1 month later...
If you space them, or make a new shelf, angle them at 45 degrees, you will have know problem. Or if you are like me and are too lazy get someone to do it for you.
Here is mine. I am happy with the result. Pics can be found here.
http://www.skylinesaustralia.com/forums/sh...&threadid=15486
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-365611
It was a tad expensive, cost me $250, but considering it took the pros 6hrs to make with all the right tools/materials at their finger tips, I think it was worth it. I could never have made something that nice anyway, no matter how much time I spent on it. And the best thing is it looks so neat and factory like that know one would suspect what in their.
The only draw back was the strong resin smell I had to endure for a week, just had to leave the windows down in the garage to let it air out.
That price was bargained too btw as I am a repeat customer!
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-366067
  • 4 weeks later...
jimbo2000 don't listen to them dude 6x9's do fit in the back all you have to do is make a new parcel shelf with 14mm spacers on a6-8mm shelf and positon your holes over the existing ones which originally fit a slightly smaller speaker did them in a mates 33 no sweat . just make the shelf itself out of 6mm and then the risers out of 12-18mm mdf whatevers thickness gives you clearance over the battery and then smooth out the spacer edges with bog cover in grey carpet easy
https://www.sau.com.au/forums/topic/13586-6x9s-in-33gtst/#findComment-414284
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
    • This is a pump I have used in the past; no oil ever leaks or gets past the regulator plug.I was trying to understand what caused Nissan to not only mention it in their manuals but to also state it's a replacement part yet the part cannot be found on my pump or on any new pumps and there doesn't seem to have ever been a replacement part#.  First time I've noticed something strange like this from NIssan.
    • yeah I have brown peeking out from in between some metal sheets close to the hood hinges. Strut towers look fine, even around the edges. some images https://imgur.com/a/brGt3Tu the one that looks the worst is the panel(s) going away right near the firewall on the passenger side, from underneath. Driver side does not look that bad.
