h all
just wondering if someone could tell me whats going on here...
when i drive normally i dont blow smoke but when i boot it this light brown coloured smoke pours out only once the revs get higher, like around 6000rpm...
it does it in 1st, 2nd and not so much in 3rd gears
power doesnt drop or anything, just this huge amount of light brown smoke pouring out my exhaust...
any help or suggestions would be great
thanks
chris
https://www.sau.com.au/forums/topic/135873-blowing-smoke/
i was under the impression that light brown smoke was infact coolent. Black is fuel, white is oil.
Check your raidator for oil, just pull the cap off and check for oil.
Also check under oil cap for white foaming (water in oil)
https://www.sau.com.au/forums/topic/135873-blowing-smoke/#findComment-2526127
Light brown Smoke is usually exhaust dust ! It usualy form's in cars that arnt driven very hard or the breakdown of materials in the muffler from heat and corsion over time.
the smokes :unsure:
Blue = burnt oil
Black = fuel
White steamy vapour = water
White steamy strange smelling = coolant
White sticky hovering vapour = unburnt oil
Brown exhaust = dust
Pretty blue and pink = Autotrans
Has the car been sitting for along time with out a good hard drive ?
Edited by ishh
https://www.sau.com.au/forums/topic/135873-blowing-smoke/#findComment-2526151
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
