Hi so my problmes are. I tried to fix my idle, well there was no issues, car idled at 650 rpm, but when i tried to do the timing and set it as per manul, with the TP off the idle was at 1200 rpm. so i cranked the acc in as far as it would go and only managed to get it down to 900 rpm, and no more. I did the computer screw aswell and nothing, the idle woudl not increase or decrease any more then 650, i don't want it lower i just want to make sure it's ok.
So i followed the guide
http://www.skylinesaustralia.com/forums/in...=110431&hl=
And did the idle reset, and nothing, with the TP off and the ACC all the way in it would not go lower then 900 rpm, and that is all the way in. The manual from nissan states that the idle needs to be at 650 with the TP off.
Once i connected the TP the idle would drop down to 650 and that's it.
The other guide however says to disconnec the AAC valve, so whichone is it
http://www.skylinesaustralia.com/forums/in...=110434&hl=
The whole reason i wan tto do this, is to set my timing properly, and i can't set it at 650 rpm with the TP off as it does not allow me to do so.
HELP i'm going insane. I am going to clean the AAC today and cheack for vacume leaks to make sure it's all good.
I have heard that testing for vacume leaks is easy if you get some break cleaner with the small tube squirt extension and squirt arround all the pipes and manifold, if the rpm go up, then there is a leak.
Can somone give me a pointer as to how else do i check for leaks, exhaust and intake, i can't hear anything, but my fuel consumption is about 350 km in town for 50 liters and about 500kms on the higway.
BTW the car has a full 3" exhauts and cat and dump, FMIC, HKS POD, .8mm plugs, timming at 15deg at 900 rpm, boost at 8psi.
SO what is up??????
On the throttle body there is a small allen head screw which adjusts the throttle plate position. It should not ever need adjusting and should have a coating of red or yellow paint on it. Has it been tampered with??
nah the TP has not been tampered with. I simply need to know which guide is correct. The one where you disconnect the AAC valve to set the idle or the one where you tunr off the TP to reste the idle?????
I rang nissan, but they are dickheads here in Tas, BLODY DJ, should be called DICK HEADS.
The TP is set as it should be 0.4V at idle
well last night i pulled the AAC valve out,a nd gave it a good clean. She was preaty dirty.
Put it all back in, tested the valves all close and open ect.
AND still no good, i had a look at the AAC valve and if all the valves are shit, there is always a small amoutn of air getting through.
So i puged it all back up, and nothing still can't get below 900 rpm as oper guide, so to check if there is a vac leak, i turned the AAC valve off and the car stalls. or dies in the ass.
I am goignt o use good old break cleaner to run arround all my piping to see what is goign on, but i don't think i have any leaks, will see.
ANY MORE ADVICE AS TO WHAT TO TRY?????????
""""""It could also be a vacuum leak.
If your idle screw is completely closed, there is definatly somewhere else that air is entering into the inlet manifold.
As was said above, my bet would be on the cold start idle control, or a vac leak, or for some reason a malfunctioning AAC assembly, where it is sitting open far too much when idling. Try disconnecting the power to the AAC assembly, that should close it and give you an idea of where the leak is comming from.
The car should stall if the AAC valve is faulty and opening too much, when you unplug it.
If that doesn't work, try pinching the bottom hose that runs past the AAC on its way to the cold start, if the idle drops when you pinch the hose = less air = stall, then thats your problem.
If that still doesn't work, check all your lines for tears or holes. Check all your gaskets on the inlet manifold, and check your throttle plate is properly closing."""""
From a Prevoius post. Ok so my cars stalls with the AAC valve disconnected, so what part is Faulty, i checked for operation and it definatly moves up and down with voltage ect. what parts do i need to replace to make this work??????
HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELPHELP HELP HELP HELP HELP
Edited by WogsRus
If you disconnect the TPS, then the ECU doesn't hacve a "throttle closed" signal, and idles up to match the reading it is getting from the AFM.
If you leave the AAC valve connected, then the ECU is going to continually adjust the AAC to maintain idle stability.
So, it makes sense to disconnect the AAC valve before you make any adjustments to it.
Yeah on the RB20/26/30 the above is true.
However disconnecting the TPS (MAKE SURE YOU DISCONNECT THE THROTTLE SENSOR NOT THROTTLE SWITCH) on the RB25 fixes the AAC valve at a fixed duty cycle (not sure exact % Nissan don't state it) which is where the duty should be at required idle setting.
I've done numerous RB25 systems and never had trouble, weird...
Check to make sure you don't have a faulty power steer switch/sensor or neutral switch/sensor, make sure the AC and all loads are off or else the system may substitute a higher duty cycle on the AAC solonoid.
Forgot to mention make sure the timing is correct or else it will generate extra torque and it will rev higher.
Edited by RB30-POWER
and hence the problwm, how do i set the timing, if the rpm does not sit at 650 rpm with the TP off as per maunal to do timing???
I'm preaty sure i have solved it anyway, it's the cold start celenoid that is letting air through to rise the rpm.
  • 1 month later...
yeah, if you remove the air regulator while its hot, it should be closed, if you look through the hole.
my air reg is f**ked. closed all the time. does not start easily in the mornings. have to help it with a few prods of the accelerator. still idles fine though.
If you undo the 4 screws holding it together, you can clean and lube the spring assembly in it and it will be good as new.
Just be careful of the gasket when you split the two halves once the screws are removed.
Once you have cleaned it and re-assembled, put it in the freezer for 5 mins and make sure you can see through the hole, just to check its working properly.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
