  • Replies 123
Posted Images
Troy: You rate Winton that low??! You've gotta get your car sorted then, 'coz I don't think I've ever had more fun than I did on that track!
You can all come around my place Saturday morning when im hanging out my laundry and you can all race around my clothes line in the courtyard. I have red, green, blue and black underwear so i can flag. Same thing as running around Winton "(
WOOHOO, YEAH BABY!!!!
Its been a long time coming, good to see ur going to have a crack!!!!
I'm assuming your 'upgrades' have arrived???
I hope you know it's all your fault!!
Yep, she should pull up a little better now :(
ps Roy, take Friday off to do what you have to do to the car and give calder another crack.
3 silver skylines ain't on the track all at the same time too often you know :rant:
I would if i could...im at the mercy of the client and the arrival of a ship at Corio Port...i may be able to get a day off late next week, but i doubt it.
Then there is of course the money thing...i need to get new suspension components as they were knocking pretty bad at Winton/Sandown :(
Next month should be better..i will have over 70hrs overtime :rant:
Sir AMEX is already knocking on my door threatening large black sex toys and my small orifices. I have done enough to put him at bay for this month....and the overtime thing...well i am doing 20-25hours overtime a week...so cant find the time to do two track days :)
Wow, what a day... awesome weather, track was perfect.. Was really great to see everyone out there going hard! I beat my PB which is what I set out to do, I'm happy :) Well done to everyone today - I was especially impressed with Justine's and Ryan's times on street tyres.. 1:10's is pretty damn good! :D
Was great to watch Archie giving the GTR some serious stick down the straight, that thing rips!!! :D A pity a few of us had to retire for the day due to various issues.. I retired due to a blown dump pipe gasket. But all in all I had a good time. The black wrx that hit the wall looked pretty harsh too!! I suppose it wouldnt be a WRX day if someone didn't write off their car heh
I'm so tired after today... After getting home at 1am this morning.. I've hardly had any sleep. Will post up pix laters! :sleep:
Well done Matt, 1:05.44 is very impressive!!!!
Well done to Archie aswell, 1:04.96 is awesome considering its been a year and a half since he's seen the track..
Aaron also had a PB, that car is FAST!!!
Good to see Justine and Ryan also punch out some good times on street tyres....
Kon (TraciTrax) made his track debut, well done mate, hope you enjoyed it...
Times are up: http://www.racetime.com.au/?event=c0608
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
