Hey all, just after some advice.
Im chasing around 250rwkw in my r32 eventually, I already have gtr injectors, 500hp fuel pump and afew other supporting mod's on my rb20, altho still stock turbo.
My question is, should I ditch the rb20 and drop an rb25det in, or go for a rebuild and stroke the rb20 to the 2.4?
I figure it will be more expensive going the Rb25 route, but Id rather go that if it will handle the power better?
Im not sure how far I can push the 2.4 and also I hate the lagginess of the rb20.
I'd like abit more info on the 2.4?
Cheers.
if you want what is the cheaper of the 2 go the rb25 .Building an rb2.4 is expensive and the rb25 will get you the power you want easy with out the lag
cheers Peter
From my personal experience turning an RB20 into a Rb24 is not worth it...
Parts are expensive and you may as well just go to a Rb26 for the same money...
For a simple 250rwkw the Rb25 is the perfect selection. Most importantlly their cheap and the parts are cheap...
(When i say cheap, their cheap in comparison to other engines.)
Its easy to get an RB25det reg'd in an R32.
Here in Adelaide they need to run the stock ecu, R33 GTST front brakes and thats it.
Unsure what the price of an R33 motor and ecu is worth these days but it 'may' work out better simply grabbing yourself an R32 RB25DE and dropping a set of aftermarket cast or forged (which ever your budget permits) pistons in it to drop the compression with a cheap refresh. For near the same cost (maybe +1k :ninja:) of an R33 motor and ecu you end up with a fresh 2.5ltr. ;)
The bonus of the R32 RB25DE motor is they are identical (sensor, plugs, injectors, bolt ups etc) to that of the RB20DET, so simply rip the rb20det out, drop the rb25 in, start it on the rb20 ecu and drive it to the tuners to ensure afr's are good, which they will be but MAY hit an early fuel cut as the ecu won't expect so much airflow at a lesser rpm.
what about an rb30 btm end underneath the 20 head?
my tuner showed me one they put in a vl with a huge turbo
and ran 10z at its first meet.
not sure what needs to go inside the engine though,can anyone help on
whats needed inside the engine?
as id like to go this route to maintain the stock look.
wow they would have some good response...prob not as good potential as a 25 head....but the idea is there.
I like the idea of a rb24 just cause it is different, i mean it is more but then you could get 250rwkw without changing the internals on the 20, just mean some lag issues....but then again do you drift on track or anything? just dump the clutch again it if is slow :) The rb20 is still one of the strongest engines, dont want lag then pump fuel and a smaller turbo and or a different cam. Also you could commit suicide and put an sr20 wth a gt28rs in if you want balls.
Haha thanks for the response's guys, still undecided, at the moment my main game is drag, but I'd like to dabble in abit of everything. The idea of the R32 RB25 sound's like a good idea, I never thought of that, tho no VVT?
I thought the 2.4 might do alright with lag compared to 2.0l, figured it wouln't be too much different from a 2.5? but judging by the responses it sounds like it would be just as bad as a 20.
Yep no VVT. The head etc literally looks exactly the same as an RB20DET. The only difference is the side of the combustion chamber, valves and larger inlet ports.
With regards to the rb20 head on an rb30 in a VL running a 10. Thats no big deal.. An rb30et (SOHC) touch over 300rwkw, slicks, stally and an auto pulls in to the 10's with SOHC. :)
i'm keen to hear about your RB24 too.
I think the 24 would be a good option, and certainly more torquey than the 20 possibly about the same as a 25 even. and it will look stock. still have the same engine number, still run on the same ecu etc etc. it definately has some advantages. but i have to agree that the 25 will probably be cheaper.
Can someone explain why RB20s scream and sound great, where as RB25s are a slightly flatter/deeper exhaust note? There is enough of a reason to keep the RB20 there :)
I do miss the scream and top end power feel where it doesn't simply nose over but just keep screaming. :)
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
