Hey im in adelaide and am looking for parts for a y31 gloria. im looking for a back left hand door and any info or possibly were i can get hold of a manual on the vg20 motor.
Thats gunna be hard.
Did you know Van Morrison wrote "G L O R I A"?
https://www.sau.com.au/forums/topic/135980-gloria/#findComment-2530871
Get in touch with Meggala, he imported a couple at one stage and he might have some contacts.
www.maggala.com I think is the web site address, it might be .au but don't think so.
Send him an enquiry and I'm sure if he can help, he will.
Cheers, D
https://www.sau.com.au/forums/topic/135980-gloria/#findComment-2538764
good luck buddy - when i originally got a vg20et i searched for months and found close to zero - have some tech specs but thats about it... i actually have a manual for a maxima with a vg20et in it but its ALL in jap.
the good thing is that all parts etc i needed to replace are identical to the vg30 so no worries there.
https://www.sau.com.au/forums/topic/135980-gloria/#findComment-2540034
yep hard getting bits for a Y31. I had one for 2 years. really nice cars. Mine was the one on megallas site that had 42ks on it.
I ended up getting an account on yahoo JP and buting things and getting them shipped over here from a freind in JP.
cost a fortune
https://www.sau.com.au/forums/topic/135980-gloria/#findComment-2577592
  • 3 weeks later...
  • 2 months later...
Hi Boof,
Did you manage to find any parts or a manual for the VG20 Engine?
I've got a Gloria myself and I love it.. but it's very thirsty and needs to run on 98 octane fuel. It hates anything below 95 octane. If I find anything on the car I'll let you know. If anyone is after a VG20 Engine & Gearbox, there's someone on ebay selling one.
Cya's.
Jeff (All Wheel Driver)
Edited by All Wheel Driver
https://www.sau.com.au/forums/topic/135980-gloria/#findComment-2840215
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
