Hi, I'm looking aorund to buy new globes for the front of my series 2 r33, have asked around a few shops, although nobody seems to know the exact globe type suits the:
headlights
parker lights
high beams and
round fog lamps.
I am looking to make change everything to phillips crystal vision globes (ice white). Although I need to know what tye of globe fitting/size/type I am asking for!?
If anyone can tell me this would be greatly appreciated!
https://www.sau.com.au/forums/topic/135982-r33-front-light-globes/
don't use any globe with a blue tint on the lens.
it inevitably cuts your light output and blue light is worse for visibility because it scatters easily when it hits air/water. this creates glare.
plus-50's FTW.
I want something that will give off the most light, not because it looks blue
phillips plus 50's
Yes I am after something thats bright white, not blue as they look cheap as. Any Ideas?
phillips blue vision give off a white-ish light, but it is only as bright as a standard bulb. i currently use them and they are better in the skyline than in other cars i've owned. i also have phillips gt150's in my other car and they work well. give off a white-ish light, but are yellower than the blue vision, and from the front have a blue reflection in them.
i'm not 100% sure, but i don't think BATMBL's bulbs are legal either. i don't think they have been ADR approved for road use, which means if you have a crash at night where you hit someone or something, your insurance company can say that your lights were part of the cause and refuse to pay up.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
