nope. non of that it was just 4th gear crucnhing a lil down shifting from 5th
i drained the sucked 2 times using ths caltex gear box oil
then i used this thing that has lead in it .. it heats up in da oil
attaches it self to the syncros and helps it out..
goes very well
il get the name of the product later
https://www.sau.com.au/forums/topic/13599-gear-box/#findComment-272066
u shutt up inark...
im at work today
after work il go to my cousin had have a look see i knwo he can order it in pretty cheap ....
it comes in a black small bottle
he also has good octain booster as well.. u add 5 mls to a full tank
works well .. oinly set make
dont stand behind ur exhaust
ul get tears in ur eyes cause the fumes
https://www.sau.com.au/forums/topic/13599-gear-box/#findComment-272736
ok i called him
its called
PRO MA thats the brand and the actualy product MBL8...
it can be run threw ur motor.. test have been done in america wher ethey run em threw truck motors
after 100,000 k's they opened it up and all internals looked like new..
il try find a web link to it tonite...
price of these are about 15 bux i think not sure
but it lasts a while and it worth it.. preety cheap il find out 100% how much for use if u se want any i can order osm in threw his company. no profit no nothing cause i love ya
except inark.. i charge u an extra 50 buxs...
https://www.sau.com.au/forums/topic/13599-gear-box/#findComment-272796
sounds good danny...
"PRO MA thats the brand and the actualy product MBL8...
il try find a web link to it tonite... "
is that the gearbox oil? or can u use it with ur engine oil too?
https://www.sau.com.au/forums/topic/13599-gear-box/#findComment-273470
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
