Hey guys, the time has come to road reg my R32, so I need to find a stock airbox. It's roadworthy right now, but I'd rather not take any chances with the rego as I'm only in town till friday to do the rego and getting a second appointment could take forever.
I just need an R32 GTSt airbox (apparently the GTS one dosen't line up properly but I could be wrong) for the rego check and I'll have it back to you as soon as I'm done.
If anyone has one lying around I can come and pick it up anytime before Wednesday.
Cheers,
Shan
wow... thanks guys... i can feel the love :pirate:
Gonna borrow Kaz's sometime before Wed arvo as she's not far from my place (just worked out that its 3 left turns and a right turn).
I'll see you all on Sunday morning for brekky tho. Hopefully with my newly registered car.
Altho I just found out the engineer's cert I had expired not long ago and the engineer who issued it is in New Zealand atm :O lets hope they accept the older one.
hehehe. good luck with that :O
they wouldnt register my car because he left RB off the engine prefix...Had to get a re write on the RWC, new appointment etc....
the car's already had an inspection, and it passed everything, cept I couldn't pay the rego as I had just paid the rego on the cef and was $50 short. How embarassment.
Then I went to syd for interviews n stuff, so left the R32 here. Now I'm back to get my car, I rang VicRoads and the guy asked me if I had already rego'd it under my name, coz the VIN and my details were already on it.
So lets hope they're a lil more leniant as it's already been inspected with that engineer's cert. I've got a current roady, so it shouldn't be that much of an issue, unless they're real diligent.
Otherwise I might have to extend my stay in VIC for a lil while until the engineer's cert's gets redone.
Im local ;) - come get whatever you need from my R32 when you're up here
Airbox etc.....
I would... cept I'm keepin my cars all with VIC reg :D sif get a roadworthy cert every year and deal with multicoloured slips for different things.... most. confusing. registry. process. ever.
Hey Kaz, do you mind if I come pick it up tomorrow morning? I'll give you a call beforehand.
Redid the booking for monday, gonna get the engineer to redo the cert on friday, and should be 100% fine then.
Which means I'll be comin to the breakfast meet in a Hyundai :D
I have nothing to offer you of any help, i didn't even read the thread, I just thought i'd take the opportunity to tell you you suck, and you look quite at home in a hyundai.
Eat me!! :(:dry:
sorry only just saw this, had no net today.. networking issues!
Anyway should be ok, going to city nissan again at some point though, about what time?
I was going to try and see if I could drop it over to you last night but I blew a hose in the city in peak hour, had to get a tow home from jack. :)
Eva fell asleep in jacks truck LOL. Smooth ride I guess :D
Eat me!! :(:)
Just for that I'm gonna come knocking on your door with a bottle of scotch and something for you to jam under my cluster.
Anywho, turns out the roadworthy guys, VICroads and the engineer didn't need the airbox fitted, so I went ahead and got it all sorted out.
Thanks for the offers in any case guys.
COOL I'm sleeping in then :) (hopefully!)
Oh probably a bit late now, but don't ever go to Carlton Vicroads.. that old grey guy in the 'drivethrough' is an utter (& bitter) prick. Greensborough Vicroads are fairly reasonable/nice though.
Burwood Vicroads is where I got it done... they're pretty easy going, although he did give me some hassle about the VIN number being stamped on the strut tower instead of the firewall.
Other than that, all done and ready to go.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
