yesterday i went to get my 1st wheel alignment in the 2years iv had the car, a bit slack i know but i have been unable to get one done up untill i changed my slightly bent lower control arm the other day. Anyway, they adjusted my front toe back to 0, apparently it was way out, which i now know ws causing my crazy tramling issues. Anyway, they brought to my attention that they could not adjust my camber (2.7 on right hand side and 1.22 on left because the right hand side upper control arm is missing a bolt, Iv got an adjustable camber setup that came in a kit with the nolathane bushes that i had installed when i got the car. ( i think it might be the whiteline one that sydney kid is selling in group buy) Im thinking that my mechanic never installed it properly in the 1st place which is obviously why iv been scrubbing tyres since..
So this is obviously the cause of the excessive camber on the right hand side, what i need to know is does anyone know what size bolt i need to wack back in there and is it just a simple matter of putting a new bolt in there or isit more involved than that??
Any help would be appreciated, im so sick of scrubbing out the drivers side tyre on the inside every few months or so, the tyre that was on there last had mostly 60% tread left but was through to the canvas on the inside... damm annoying
Thanks guyz!
Edited by blackprincegts
https://www.sau.com.au/forums/topic/136052-front-bolt-on-upper-arm-missing/
The missing bolt will be the same as on the other side of the car. From memory (depending on which of the two it is) it is a 12mm dia machine bolt with an additional lock nut.
Pull the good one from the other side & go and find the same at your local fastener store. As long as there isn't any major damage you will be fine, but I would replace both bolts in the upper, outer position as a minimum as the remaining one will have been well stressed.
make sure the bolt has exactly the same amount of shank on it before the thread so its solidly secured all the way along until the thread comes out for the nut, which are crushed end lock nuts, not nyloc nuts. People refer to them as exhaust lock nuts as well. If you explain the situation to the bolt bloke im sure he will know what your on about to give you the right bolt.
Only go to an industrial bolt and fastner place or bearing place to get the bolt and nut. Dont goto supercheap please.
Sounds like you have the shorter of the 2 bolts (25mm) installed but it's missing the 50mm long one and the lock nut that goes in the front as djr81 said. The kit is designed so that the 50mm long bolt bottoms out and so turning that turns the crush tube, then tighten up the lock nut and short back bolt to hold it in place. There should be a spring washer under the bolt head/lock nut too.
12mm thread sounds about right, i have a feeling it's 1.25 pitch aswell.
I think r33 racer is thinking of the stock arrangement with a single bolt that goes right through the bush, rather than the Nolathane version with a bolt at either end.
Yeah the bolt i got missing is the one that doesn't have the additional nut on it that adjusts the camber. Ok im thinking this is going to be allot of mucking around. I hope i dont have to go and buy a kit for it because its been damaged.
After what you guys have said im thinking maybe i should be getting one of my mates whos more mechanically gifted than myself to help me pull apart the other side and compare the two..
thanks to all for the input!!
Actually now that I kind of know what im looking for i went and had a really good look at it. It would seem that im going to have to pull the whole things apart because the front hole where the bolt should slide through and im guessing slide through the middle of the nolathane bush is sort of shifted, its only half inline with the bush by the looks of things.
Its obviously shifted in the past and sort of lodged itself there... damn i rekn this will be annoying and difficult to fix.
If that is all it is the job is very easy. Just pull the one out of the other side & take it to a proper fastener store (Not Bunnings). They will sell you something like an M12x25 & a M12x50 machine bolt probably in either a UNC or a UNF thread. Should be a grade 8.8 or better. Anyway the blokes at the shop will be able to tell from the markings on the bolt.
This will cost you all of $5 to get sorted.
Alrighty then, ill givit a go when i getta chance, if i get stuck then iv always got mates who are on emergency callout standby..
im shockd and amazed that no1 else found the problem, i tookit to suposedly suspension expert places and all they sed was that it was my lower control arm. small independant place down the road were the guys to find it.
im lucky the other bolt hasnt just snapped!!
thanks again for all of your valuable help!!
a fine or coarse thread, not unf or unc as they are related to imperial thread types. If your not sure just remove the one from the other side and take that with you as has been suggested before. It would be interesting to know what grade the std suspension bolts are from the factory, cause we dont use anything less then 12.9 on the race car when fabbing something up or replacing other bolts and nuts. No one uses grade 4 anymore its piss weak, grade 8 is the new 4 and 10 the new 8. Overkill is a 12 :)
Ok fellas, I got the 2 bolts i need now. Its the 25mm bolt thats missing.
The problem im having now is that I cant seem to get the arm and the bit where the bushes are installed to line up properly. Iv tried loosening off the bolt with the lock nut and that enables me to move the arm around and make it almost line up but theres about 0.5mm that what alighn and allow me to install the new bolt.
If i was to remove the large 50mm bolt completely what would happen? I havnt removed it all the way yet because I dont want the whole arm to drop down and then me not be able to get the bolt back in.
The 50mm bolt thats in there is pretty damaged btw, all the thread has been worn off where the pressure has been on it.
I want to try and sort this out asap, even though its been like this for like 2years now that i know about it it makes me paranoid when im driving the car
Thanks!
Please, anyone??
Surely someone would know a few pointers as to removing the two bolts and would now what would happen when i do it???
Remove the shock/spring unit
Unbolt the stabiliser bar
You should them be able to remove/replace the upper control bolts easily
If you can't then you will have ot unbolt the radius rod from the lower control arm.That will enable the lower control arm and the upright to move around freely.
Then it is a piece of piss to remove/replace the upper control bolts easily
:laugh: cheers :O
:laugh: cheers :O
Awsome! Thankyou very much!!! Id better be allowing mself a couple of hours for this job i think. I had a feeling that i would have to unbolt the strut because it looked like it was stopping the up and down movement.
Cheers
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
