Been having problems with what I believe to be something to do with coilpacks. When I am in first and I plant my foot the car will quite often get to a point where it will just "stall" and the revs won't want to keep going. Like it gets stuck at a certain rev range and I gotta change gear. I have had problems with coilpacks before and its not misfiring really badly, but it does feel kind of similar. The car feels kind of jumpy and not to happy. A mate of mine pointed out that my unstable idle could be a sign of coils? I just cleaned out my AFM so it should be pretty clean. It also tends to happen mostly when the engine is hot after I have been driving it for a bit
I am just curious to see if there is anything else it could be?
Edited by patto1234
Does it pop and misfire when you get to this point?
A good way to check the coilpacks is to take the cam valley cover off. Take it for a good spin at night, get it nice and hot and put it in a dark shed and keep it running. Give it a few good revs and see if you can see any blue sparking from the coilpacks to the head.
Try gapping the plugs down to .8 and then .6, if this fixes it then its a spark related problem and most likely your coils.
If the plugs are old though it could just be them.
It doesn't really pop or misfire so much, rather it just gets bogged down in a particular rev range and sounds like it is struggling. They are the original coils so there is a good chance thats the problem.
It shouldn't be my fuel pump as I have an aftermarket Walbro item which I don't think is that old. I figured it must be something to do with the coils, the gapping of plugs or perished sparkplugs or something like that. But I just wanna get a better idea of what Im looking at having to fix
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
