N1 Oil Pump Killed My Engine .....
campbell
 Share
  • 11 months later...
  • Replies 105
So does that $1200 price estimate for a JUN/Tomei/Trust oil pump fitted include an enlarged sump, external oil return, head restrictor and baffles. Or are those extras costs? if so can sum1 give me an estimate for that too.
is there a cost difference or preference between the brands?
cheers thanks for the info
your looking closer to 2.5g's for all of that.
what spec is the car? fair chance you might not need it :dry:
yeh i thought that was too good to be true hahaha.
You are right that i dont need it definitely not now anyway. even for what i would want to do to my car in the future i probably wouldnt require that serious a oil setup. but for 1200 big ones i thought it might be worth it.
I've got new N1 pumps for my 25 build... not worried as its really a circuit motor that won't be pushing much more than 250rwkw... almost standard rev limit and baffled/circuit sump, restricted feeds etc
what I want to know is should I run the crank collar or not... I suppose logic would suggest with the price of the collar its cheap insurance?
also guys that have had the pump fail are you sure you it wasn't detonation that pounded the crank which may have cracked the pump? might be a case of which came first the chicken or the egg? most had forged pistons which can take a fair bit of detonation before they are damaged... of course I would expect some pretty smooshed bearings in this case as well...
will do cheers Geoff... I must admit I haven't looked closely at the old pump even tho its been sitting on the garage floor for weeks! I'm just replacing everything that goes up and down or round and round regardless of condition... and its all pretty stuffed hehe
  • 7 months later...
i spoke to them at high octaine in sydney they recomended them as well as a few othe r people building big hp cars but i guess i no now,,,,,
thats weird because my mate works at hioctane and he recommends the tomei oil pump's over the N1
f*k me i just read through the 1st page......i decided to go with the n1 pump and the collar thinking that it would suit wat i wanted.
pretty much a weekend car now, occasionally the spirted run. very rarely will see anywhere near the redline. and maybe take it to the strip when saturns moons perfectly align every now and then.
should i be worried with 350-400kw and a n1 pump?
i just couldnt justify spending 2-3k on a oil pump, but if its going to cost me my engine......maybe i should have..........
Edited by R34NRG
Been thinking the same thing :)
Just stay off the limiter and you should be sweet guys.
thats a very "bandage" solution there buddy :blink:
and pointless when your at this power level.
i agree we shouldnt punish the limiter, but what are you gonna do at the strip? or any other location for that matter when you do want to give it a lil
Then pull your engine out and replace it. Don't ask for advice if you are:
1. too foolish to have worked it out beforehand, and
2. a weekend warrior who is going to bash the advice of an engineer that has worked in the V8SC pits.
What would you like? Shall we get a roster together of people who are going to come hold you hand? It's not the mediocre power figure that is critical. It's banging it hard on the limiter. Even the most incompetent drivers will soon learn not to. The only other option aside for staying off the limiter is lift the redline to where you can't hit the limiter. Common enough practice if you are aware that it isn't there for every day. For Sandown I used to run an extra 500rpm so I didn't have to shift up between turns 1 and 2, but I didn't then use it for the rest of the track and it was locked down again as soon as the day was over.
Now, it's the weekend, so either get back in the playpen son or go do some of that traffic light drags you must be aching for.
LOL, Have another stogie Geoff. :blink:
I was so undecided as to wether to spend the extra tin on a better pump but the more research i did made me do it and quite a few oil mods at the same time.
I ended up using the Jun pump and collar and darn glad i did.
well I don't beleive that you need anything other than an n1 pump unless you are really going to be abusing it (eg rev limiter launches etc). for your average rebuild an n1 pump is fine.
that pump posted above clearly shows huge abuse. You can't really complain if the pump cracks when you are doing that to it. Lucky the pump died before the rod jumped out of the block.
We run n1 pumps in the race and targa cars and have never had a problem. Probably used 10 of them over the years. this inclues many race launches (not from redline though)
btw yes you might hit the limiter if you are not paying enough attention to your driving - its when you keep it there you have a problem. the drivers foot is what controlls the revs not the limiter in the computer.
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
