btw yes you might hit the limiter if you are not paying enough attention to your driving - its when you keep it there you have a problem. the drivers foot is what controlls the revs not the limiter in the computer.
  • Replies 105
Bet you have a "Duc" hidden away in the garage with no redline on the tach and factory option 3 day beard and woggy voice.....:)
Guys,
Just to confirm
I have an n1 oil pump in my setup for my R32 GTR.
Expected power is between 280-320kw atw.
I do not thrash the car, it is used as a daily, I have never hit the limiter in it before, but I do like to drive the car hard sometimes (again does not hit thel limiter, but is put through the rev range.)
Should be fine?
IOWNU, should be fine. They are saying that basically the only way to kill the n1 pump is to be bouncing off limiter all the time... My car has n1 pump pushing out 400rwhp and its gone fine for almost 25000kms of fairly hard driving sometimes. Seen the strip a few times...
Edited by NoFX_Hardcore
IOWNU, should be fine. They are saying that basically the only way to kill the n1 pump is to be bouncing off limiter all the time... My car has n1 pump pushing out 400rwhp and its gone fine for almost 25000kms of fairly hard driving sometimes. Seen the track quite a few times...
Cool thanks man, needed some reassurance thats all....
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
