I read on a website that NSX's can have a tendancy to smash (literally) oil pumps, when they expand, the clearances become to tight and BANG! Maybe something similar with the N1's?
  • 11 months later...
  • Replies 105
So does that $1200 price estimate for a JUN/Tomei/Trust oil pump fitted include an enlarged sump, external oil return, head restrictor and baffles. Or are those extras costs? if so can sum1 give me an estimate for that too.
is there a cost difference or preference between the brands?
cheers thanks for the info
your looking closer to 2.5g's for all of that.
what spec is the car? fair chance you might not need it :dry:
yeh i thought that was too good to be true hahaha.
You are right that i dont need it definitely not now anyway. even for what i would want to do to my car in the future i probably wouldnt require that serious a oil setup. but for 1200 big ones i thought it might be worth it.
I've got new N1 pumps for my 25 build... not worried as its really a circuit motor that won't be pushing much more than 250rwkw... almost standard rev limit and baffled/circuit sump, restricted feeds etc
what I want to know is should I run the crank collar or not... I suppose logic would suggest with the price of the collar its cheap insurance?
also guys that have had the pump fail are you sure you it wasn't detonation that pounded the crank which may have cracked the pump? might be a case of which came first the chicken or the egg? most had forged pistons which can take a fair bit of detonation before they are damaged... of course I would expect some pretty smooshed bearings in this case as well...
will do cheers Geoff... I must admit I haven't looked closely at the old pump even tho its been sitting on the garage floor for weeks! I'm just replacing everything that goes up and down or round and round regardless of condition... and its all pretty stuffed hehe
  • 7 months later...
f*k me i just read through the 1st page......i decided to go with the n1 pump and the collar thinking that it would suit wat i wanted.
pretty much a weekend car now, occasionally the spirted run. very rarely will see anywhere near the redline. and maybe take it to the strip when saturns moons perfectly align every now and then.
should i be worried with 350-400kw and a n1 pump?
i just couldnt justify spending 2-3k on a oil pump, but if its going to cost me my engine......maybe i should have..........
Edited by R34NRG
Been thinking the same thing :)
Just stay off the limiter and you should be sweet guys.
thats a very "bandage" solution there buddy :blink:
and pointless when your at this power level.
i agree we shouldnt punish the limiter, but what are you gonna do at the strip? or any other location for that matter when you do want to give it a lil
Then pull your engine out and replace it. Don't ask for advice if you are:
1. too foolish to have worked it out beforehand, and
2. a weekend warrior who is going to bash the advice of an engineer that has worked in the V8SC pits.
What would you like? Shall we get a roster together of people who are going to come hold you hand? It's not the mediocre power figure that is critical. It's banging it hard on the limiter. Even the most incompetent drivers will soon learn not to. The only other option aside for staying off the limiter is lift the redline to where you can't hit the limiter. Common enough practice if you are aware that it isn't there for every day. For Sandown I used to run an extra 500rpm so I didn't have to shift up between turns 1 and 2, but I didn't then use it for the rest of the track and it was locked down again as soon as the day was over.
Now, it's the weekend, so either get back in the playpen son or go do some of that traffic light drags you must be aching for.
LOL, Have another stogie Geoff. :blink:
I was so undecided as to wether to spend the extra tin on a better pump but the more research i did made me do it and quite a few oil mods at the same time.
I ended up using the Jun pump and collar and darn glad i did.
well I don't beleive that you need anything other than an n1 pump unless you are really going to be abusing it (eg rev limiter launches etc). for your average rebuild an n1 pump is fine.
that pump posted above clearly shows huge abuse. You can't really complain if the pump cracks when you are doing that to it. Lucky the pump died before the rod jumped out of the block.
We run n1 pumps in the race and targa cars and have never had a problem. Probably used 10 of them over the years. this inclues many race launches (not from redline though)
btw yes you might hit the limiter if you are not paying enough attention to your driving - its when you keep it there you have a problem. the drivers foot is what controlls the revs not the limiter in the computer.
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
