You guys are so in the 20th century :)
The latest way is microfibre chamois....
http://waxit.com.au/proddetail.asp?prod=MT7001&cat=6
Here are a few more tips for those of you who have never used a chamois, who knows what else you are missing *looks at OP*...
http://waxit.com.au/howto.asp?howto=1
my mum bought one of the ones that had the soapy shit all through it. biggest pain in the arse out. i have used a new synthetic one and its not as good as my old one. my old one dries the car completely. it is actually a synthetic one, not leather as i stated in my first post.
MAN i hate this chamois crap..
Doesnt work..
Either that or i dont know how to use it.
I rather use a cloth.. But it does leave flur a bit. But i now bought some special cloth just for drying.. leaves no flur or anything..
But i used the chamois for the first time.. never again..
doesnt even soak anything up.
and i paid like 15 bucks
anyone in sutherland shire area can have it for free.
Doesnt work..
Try the meguiars one...u won't go wrong...u'll find it takes less time to dry ur car compared to normal cloths...
Werd...Meguiars microfibre chamois, microfibre applicator, microfibre detailing cloth & microfibre dust cloth is where its at. :P
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
