Hey peoples
Im after an R33 rb25det turbo thats been high flowed
Prefer NO shaft play.
Will consider stock turbo for a good price.
Turbo must have wastegate actuator attached.
Let me know
Guesty
https://www.sau.com.au/forums/topic/136144-r33-standard-or-high-flowed-turbo/
You're not really making this easy to be honest :)
You can get a shitty 2nd hand turbo for around $4-600, or you can get a GCG highflow for well over $1000 (i think its about 1700 from memory) or you can go for a Slide highflow new for $890 - the thing is, all people can do is offer, you have to make the choice ;)
Well im willing to pay upto 1800
wats the difference between the GCG highflow and slides ones?
quality? performance? why the big difference in price?
Thanks
Thanks
The difference is the GCG ones are Ball bearing and the Slide ones are Journal bearing (which most skyline turbos are from factory). Also the GCG ones have to cover costs the Slide ones dont have to, like advertising and rent on properties, land tax, wages for heaps of employees etc
Both support 250rwkw with ease, it all comes down to how much you want to pay really
No difference in quality, no Slide ones have failed, and the quality control is the same, Depending on where you are located it can be installed aswel to make it easier for you
So the only difference is ball bearing Vs Journal bearing.
Is journal bearing the same as bush bearing?
Other than that the qualitys is the same. Both are good.
Wat would u recommend. Money isn't really the issue.
quality is more important.
Im located in melbourne also.
There have been many threads on this and Slides turbo's have always come up as top quality and the best value for money with the same results as GCG's
Hope this helps :D
You've been a great help
Thanks heaps
Hope this helps :D
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
