I cannot read Japanese but I’m going to attempt to anyway. :):P It looks like an Rb25det conversion into an r32 GTS-4, it would seem the motor cost 500,000yen with 38,000yen worth of labor costs. It also appears below the costs it is dated and maybe has a recommended run in time. :)
I sought of figured the rb20 to rb25 thing :) was mainly after what the japanese writing below the english meant :P and perhaps find out when and where it was done.
Edited by CeJay
Close... but no cigar. Actually, you WAY OFF :) 38,000yen was for a metal head gasket.
They used the R34 turbo that was already present on the old engine,
A nismo clutch with flywheel (I take it 'F/W' means 'flywheel')
Stock cams have been taken out and taken away(?) Maybe they used the RB20 cams in the RB25...(?)
  • 2 years later...
* エンジンRB20→RB25(乗せ換え後、7万キロ走行) (Engine RB20 -RB25 Done 70,000kms)
* タイミングベルト交換済み (Timing Belt Changed)
* R34タービン アウトレット HKS (R34 Turbo Outlet HKS)
* 東名パワードポンカム (Tomei poncam)
* エアフロ Z32用 (Air flow Z32) meter
* 燃料ポンプ R34 (R34 Fuel pump)
* コンピューター現車セッティング(テスタロッサ)Computer setting Testarosa
* アペックスN1マフラー (Apex N1 muffler)
* フロントマフラーアペックス (Front muffler Apex)
* インタークーラー HKS (Intercooler HKS)
* オイルクーラー トラスト (Oil Cooler Trust)
* ブーストコントローラー (Boost Controller)
* LSD ノーマル (LSD Normal)
* ブレーキマスターシリンダーストッパー (Brake Master cylinder stopper)
* ブレーキメッシュホース (Brake mesh hose)
* 足廻り TEIN NA (Tein NA) maybe Tein suspension
* GTR用車高調 Not sure on this one!!
* クスコタワーバー(フロント・リア) (Cusco Tower Bar front and rear)
* TEIN ピロテンションロッド (Tein Pro Tension rod)
* ガッチリサポート (Gachiri support) maybe solid support
* フロアサポートバー (Floor support bar)
* N1ヘッドライト (N1 headlight)
* 後期テールランプ (Tail lamp) Rear??
* R33GTRシート(運転席・助手席)(R33 driver and passenger seat)
* ニスモ フライホイール(2万キロ前に交換)(Nismo flywheel 20,000 km was changed)
* ニスモ セラメタクラッチ(前オーナー談) (Nismo ceramic/meatal clutch owner changed. Not surte if its ceramic metal clutch..katakana says sermeta clutch
* ニスモ 強化クラッチ (Nismo strong built clutch)
R32 4WD RB25ターボ!!もちろん5速マニュアルです! R32 4wd RB25 Turbo of course 5 speed manual)
Not 100% of kanji but thats best I can do.
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
