i got pics of a white r33 s2, with work crkais lol.. .
For all silver s2 owners look here.
http://www.skylinesaustralia.com/forums/in...howtopic=136226
hopefully this post might help you
Edited by siddr20
I have a silver s2 also, finding that its a hard colour to choose wheels for!
I think so far the top 3 are
- polished chrome lip with black or grey inner rim
- full shadow chrome
- possibly a not too over the top chrome rim ie. a simple 5 spoke...
Normal silver looks alrite imo
Dpends on the look you going for, Silver is pretty forgiving....
black/bronze/gunMetal If you want the tough look.
pretty much anything goes. Siddr20 just put white and it looks good too.
don't mean to hijack this thread ..but I have a set of work vs-xx 17*8 wheels up for sale if anyones interested.
Specs are 17*8 PCD114.3 5 hole Offset +36
Came off my stagea coz one of the wheels had a crack on the outer band. Got a new band made and the repair shop told me its ready by next week. Couldn't wait the %^%$&* looong time it took to get the band made out so I've already bought a new set of rims.
Look in the WA for sale section for pics. Was looking for AUD1400 for the rims but on hindsight it is a tad bit pricy...so pm me your best price and I'll consider the offers.
fugg me I never thought gold would suit the silver s2?!!
might have to do some photochopping...
anyone recommend some nice gold rims with some polished lip goodness?
Gold rims on a silver car is classic mate! Nothing suits them more in my opinion, apart from maybe black...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
