not the normal "pull the fuse" type question but here goes
I want to do some burnouts, I know it is best to remove the driveshaft but torque is still transfered to the front wheels, just not put down onto the ground due to well... lacking a drive shaft :)
Soooooo
- if i remove the drive shaft do i still get "full" power to the rears for roasting or only 50% as the other 50 is being transfered through the imaginary drive shaft
or
- if by removing the fuse AND drive shaft, i eliminate the normal "residual pressure" issue will i get more power to the rear?
Hope you all understand what i am asking here...
https://www.sau.com.au/forums/topic/136169-burnouts-in-stagea-question/
I have pondered this myself Alex,
Depending on how the transfer-case actually works and how the power is "split"... I guess in theory if the front shaft is removed and the 4WD system is still active the clutch packs will be compressed but as they have nothing rotating them they will just sit there happily. The output will be spinning away on the transfer-case (where the front shaft was connected) as will the rear shaft (driving the rear wheels) How much power does it take to spin the disconnected transfer-case? I guess that would be "the loss", and as it is just free-wheeling I can't see how it would drag too much power from the rear drive...
Interested to hear what the actual answer is, but I won't be dropping any wheelies!
I think Japsphere has a good example of how it didn't effect his car on the dyno with a great rear-wheel figure from a stock car.
Cheers
Luke
turning the big chain and gear in the transfer case that drives the front shaft wont take much power at all, though its one damn heavy duty setup when u look inside the transfer case. i drove around in 2wd with no front shaft for the whole 1200km without a hitch and damn did it do some crazy donuts and skids :)
oh the memories :)
wont be long until i do it again with alot more power and ill be sure to get a video of it when i do ;)
i got pics of the transfer case internals on my other hard drive, ill post them up when i get time to show ya's whats inside the case
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
