Labour Cost Of Swapping Turbos On A R32 Gtr
Pretty sure that's fine. 2 kg/cm^2 on the gauge is what I see on an RB26. Honestly, 10W60 doesn't seem to move the needle that much as far as oil pressure goes on a stock pump + sump except at cold start where it looks like it's pretty much pegging the oil pressure gauge. -
By Watermouse · Posted
Maybe try a rare earth magnet to coax to the drain hole. They aren’t expensive and damn powerful. Sorry if this has already been covered -
Well, Nissan says So factory expects 0.11Mpa or or 110kpa or 1.1bar or 16psi (which feels low to me, but there you go)
Ok thanks guys that is what i thought and learned from all the comments/videos too. If i want to BoV i need/want to have standalone ECU 🙂 And the bypass valve tge car has is good for stock(little bit more) power.
By myrbgivesmeheadaches · Posted
Wait so is it heaps low or double what it should be..?
