Recently upgraded the brakes on my GT-T. Just thought I should mention especially the pads I'm using, which thus far perform well and came in significantly cheaper than some other options I was looking at (i.e. Endless).
They're made by QFM (Queensland Friction Materials), a company I'd never heard of but apparently those in the know reckon they're pretty damn good. I'm using the A.1.RM compound, which is not their most aggressive compound but perfect for street/trackday use. Temp range is apparently 0-700 and coefficient of friction is comparable to the Endless pads with a similar range (CCX, etc.).
The best part is they came in at less than $300 for a set, front and rear. Thus far they perform well, very good from cold with a better pedal feel than the previous Endless pads I've tried (EuroX and NA-R). Not noisy at all either. Can't really comment on dust 'cos my wheels are filthy at the moment... Looking forward to giving them a nice workout at QR in November (thanks MountainRunner).
Otherwise I've gone down the route many here probably have, which is DBA 4000 slotted rotors on the front (RDA don't make 310mm front rotors for the R34 GT-T), RDA slotteds on the rear, braided lines and Motul RBF 600 fluid. Feels pretty damn good so far.
Anyone else here have any experience with the QFM pads?
Here's the company blurb:
Queensland Friction Materials P/L is an Australian owned and operated company, specialising in the manufacture of disc brake pads. Key product features include; exceptional performance and pedal feel, low dust, long life with virtually NO disc rotor wear, and excellent cold stopping performance. Non asbestos formulations for automotive and industrial applications, which surpass performance requirements of Australian design rule 31. QFM Disc brake pads are used and recommended by leading Australian brake specialists.
Address: 5/34 Lawrence Drive NERANG QLD 4211
Phone: 07 5596 1099
Facsimile: 07 5596 3347
Email: [email protected]
https://www.sau.com.au/forums/topic/136212-r34-gt-t-brake-upgrade/
Just cleaned the car today (it was pouring rain so I just squirted some detergent on and went crazy with the sponge!) so I'll keep you guys posted on the dust.
These things pull up so well.... won't be able to comment on how they feel after 5 hot laps until November though. :laugh:
Even if I only get 12 months out of them, at ~$250 for the set WHO CARES????
Initial bite VERY good. I have to re-adjust my reflex in traffic, sometimes getting more stoppage than I intended, though that could also be having the fluid bled properly. Pedal feel is excellent for street.
My previous pads were Bendix Heavy Dutys and the QFM's initial bite is better than these and WAY better than my old Endless EuroX pads. The Endless were awesome once they had some heat into them though, but the QFMs are comparable definitely - tried a couple of big stops on a quiet road last night.
I won't give a final word til I've put them through their paces at QR though.
I'll post pics of dust after a few days driving.
Update for everyone.
Been driving on these for a week now.
Dust is minimal. Better than my old Bendix Heavy Dutys, similar to old Endless EuroX. Pic attached is after 500km of city driving. The wheels were not sparkling clean to begin with - as you can see the dust is minimal.
Noise - mild "grinding" noise when cold at very low speeds and pedal pressures. Otherwise no taxi-like squeal. Sometimes a bit of "groaning" as you're coming to a stop down thru 60kmh but this may be due to the rotors.
Pedal feel is very good. Certainly the best I've experienced in my current car. Much easier to modulate the brakes and pedal effort is less, though it would be hard to say how much of this is due to the pads and how much is due to getting the fluid bled. My feeling is that I probably had a little air in the system before.
Performance is good from cold, MUCH better than my previous Endless which definitely had a need to get some heat into them (one hard stop was enough) to work well. I haven't given these a massive thrashing on the road because I don't drive like that on the road as a rule, but with heat they only improve. Certainly haven't got them to fade, which was very easy for me to do with the Bendix HDs.
I'm impressed so far, but I won't be that impressed if the pedal goes long after a lap at QR...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
