-check your brake pads before you go. QR will use a bit of your pads up.
-new brake fluid is a good idea as Bunta said. and it probably wouldn't hurt to use a good 600deg fluid in whatever brand you like.
-if you have time, it certainly won't hurt to run some ducting to the front brakes - QR is hard on brakes.
if you are pushing hard on normal street pads you will more than likely get brake fade before the end of your 5 hot laps. if that happens, don't panic, there is stil a surprising amount of retardation available even if the pedal is on the floor, but a few pumps would help too. back off, but stay out on the track to help cool the brakes with some airflow over them. just make sure to keep an eye on your mirrors and wave people past on the straights.
-make sure your coolant system (incl hoses and belt) is in good condition before you go. it will be HOT out there on the track in November. Might not hurt to take some coolant with you just in case the car gets a bit hot on the track.
-change your oil if its anywhere near being due for it, or if its a very 'thin' oil. Due to the heat out there you will probably want to go to an oil with a slightly higher hot viscosity than you need for the street. Do R34 GT-R's suffer from oil surge like the R32 GT-R does? I always run an extra litre in my car for this purpose, but you might need to ask someone who knows the 34's better.
-oil cooler is a very good idea, but not essential for 5 laps.
-oil catch can could be a very good idea, but normally is only a problem with high revs and high cornering G's, which isn't really an issue if you're on street tyres.
other than that, on the day make sure you start with plenty of fuel and have checked your oil, water, and tyre pressures before you start. On most road tyres I'd be running something like 35-38psi on the track. And you can expect the front left to cop a hiding!
remove your spare and jack from the boot, and the babyseat could probably come out too :(
When you park in the pits after a run, do not pull the handbrake on - it can cause rotors to cool unevenly and warp/crack through conduction with the contact of the pads, wether they are drum inside the rotors or use the calipers. It's also a good idea for the same reason to roll the car back or forward a couple of feet every few minutes until the brakes have cooled off a bit.
Also pop the bonnet when you stop in the pits - it will let alot of heat out of the engine bay.
On your cool down lap (which is nothing like enough to cool everything down), keep your speed up enough to encourage airflow through the rad & engine bay, and over the brakes. Use the brakes on your cool down lap, but only very gently - this will help dissipate some heat out of them better than staying off the brakes entirely.
you'll have a ball! Paul runs a very well organised day, and its good fun being there with all the other Skylines and other imports.
very educational.......
as for the oil surge, how likely is it to happen?? should i at least get a sump baffle kit befoe i start going hard??? what about oil pump?? how long would the stock one last?? heard some nasty stories abou the N1 pumps recently, makes me wonder.....
Oil surge will happen if you don't have enough oil in the sump. So over fill it.
You don't need a baffle.
Stock one should outlast the rest of the engine.
Stories about N1 pumps only surface when the install is done incorrectly, don;t worry about it.
Also, when you get back to the pits leave the motor on with the bonnet up & let it idle for a few minutes - this keeps things circulating & will help cool it all down.
best thing you can do for the longevity of your oil pump and the drive collar is to stay off the harsh factory rev limiter.
franky, it will be fine with an extra litre of oil in the sump. No need for sump baffles for the occassional track day - especially if its on street tyres. Even on semi slicks it will be fine. that's how I've been running my car.
hey i got a general question for track use. what tyre pressures will give the best grip and agility. I run 40psi everyday but i was thinking a lower tyre pressure would give more contact surface area. however lowering tyre pressure too much would sacrifice steering response time and run the risk of rolling the tyre off the wheel am i right?
cheers, i will be doing my turbos soon, and the engine will come out to make everything easier. then i can do something about my oil control just to stay on the safe side of it...lol
as for the rev limiter, i have never hit it with the way i drive it......never since i got the car, so it is a good sign,lol
Keep your pressure where they are. You are right about rolling a tyre off the rim, which can happen if pressures with street tyres are too low and you catch a ripple strip at the wrong angle. 35-40psi ensures you have good sidewall tension and don't get the tyre folding under itself.
100mph tape over your balancing lead. Vibrations can take your confidence out of the car.
With semi slicks we used to run 26psi cold. After a few laps they would grow to about 32-35psi. This will happen easily in summer obviously cause of higher ambient temp and track temp.
Cooling efficiency is of the utmost importance especially in summer, so think logical as to what is going to get hammered by the heat in your engine bay: wiring, i/c hoses, water, oil and vacuum hoses/lines. People with aftermarket management, chances are in the heat knock may and probably will starts occuring so if you can be aware of the engine warning light or handcontroller be prepared to retard ignition timing a few degrees to help save those rings/pistons. Last thing you want to do is push your car to limit safely on the track and it starts rattling because the tune is near the limit. In my experience so far whatever the highest knock was on the dyno whilst tuning, on the track it is about 30-40 higher!
Edited by r33_racer
I also use some octane booster. This is possibly controversial in some quarters but for me it worked great, got rid of my knock values on the PFC entirely (never see one over about 24 now). I use Nulon Pro Strength Octane Booster at the recommended strength (one bottle/tank). You can get it at any Supercheap or Repco, about $21 a bottle.
Also my car CHEWS fuel like you wouldn't believe. Last track day I did probably 90% of the sessions (missed the Sportsman sessions due to failed HICAS lock bar) and got through a full tank of fuel (65L) and almost all of the extra fuel I brought with me (40L). So I'd recommend picking up a couple of the larger 20L jerry cans, stick a little octane booster in 'em, fill em up and stick em in the back seat so you're not having to do a dash to the nearest servo with 98 octane half-way through the day. Those with factory tunes might not use QUITE so much fuel though, lol.
Another good tip for getting my water temps under control was simply to send the radiator away to get reconditioned. Costs about $100. My car's only a '98 but the rad was pretty full of crap and now I only start to see the needle get past half-way on lap 5, whereas before I had to back off on lap 3 for a cool-down. I'm also using Redline Wetter Water which seemed to help too.
Thought about this topic quite a bit the other night...
I thought most has been said, but i just wanted to add that I personally take lunch...
Most important to take lunch... There is no food at QLD raceway and you need to come with the esky and some sandwich's...
With out lunch you cannot have a good day...
This is a serious post as i have been to a trackday with no food before... :)
if your rims are balanced with lead weights when you get new tyres fitted to them, after some racing when the rims get extroadinarily hot from the all the laps plus the high speeds they can fly off and then your wheels go out of balance and you get vibrations through the steer. So racing trick is to stick some 100mph tape over them to hold them onto the rims :) Though slicks with all the peel build up will also cause vibrations until it runs off as well incase anyone is running full slicks and cant work out why they are getting steering vibrations with their lead still attached. After a lap or two it runs off on its own so if your too lazy to rub it all off then no dramas.
We also use the octane booster, but it only drops our knock by about 10 points, but it also depends on how much you get normally from the tune. So obviously it will vary from car to car. Weve been using the Martini one.
Edited by r33_racer
Cool, this topic has been ver helpful. One last question i only got a very average amount of power at the rear wheels but i still cant seem to get the power to the ground powering out of corners it always just ends up as a bit of a drift. Would the best option be A just put up with it and go hard B put the stocko's on the rear, your only gonna fry the tyres anyway might as well help save the hip pocket or C Power later when your car body line is straighter.
adjust rear suspension, whether spring rates, swaybar settings
adjust ride height possibly
try some larger rear tyres if budget can allow it
try to power on a little later on in the corner exit
different gearing if possible, try a gear up whilst exiting a corner if ratio and power is too low and high for that particular corner
If you change to stockos you will only ruin your times everywhere then which is no fun. Try to change your cars setup to aid in faster corner exits or try and play with your driving style and see what works and what doesnt.
This is a serious post as i have been to a trackday with no food before... :nuke:
Good point...lunch + plenty of fluids (non alcoholic :) ) is very important
Just to keep things in perspective our TOR car GTS25T has nil engine mods, we added an oil cooler and lost the muffler...thats all. We do have a modified suspension, Rotors were stock with red stuff pads f/r.
The car ran 127 laps of the Nat circuit in the Qld 500 with absolutely nil problems. The tires lasted , the pads lasted....just. The Skyline basicly is a good reliable car and CAN take a bit of a thrash without getting your knickers all knotted up. Going as fast as you can on shitty tires is just as much fun as it is on good tires. The main thing is to actually get out there and enjoy...not ..waiting until you have got this done or that done. If you can drive a stock GTST to it's limmit you will be quicker than a lot of modded cars and a few GTRs.....Have fun with YOUR car
See you out there
Yeh but the trick is actually being able to safely push the stock car to the limit and be able to hold it there all the time, rather then always pushing it over the limit and losing time. A modded car is alot easy to drive and hold near the limit so to say as its been built to do that.
cool, thanx for your help. One final question i re-read the timeattack website and it says when a car is behind you ready to overtake, you must indicate when they are clear to do so and not have a car next to you during a corner. When they are over taking are you suppose to back off the throttle so the over take can finish sooner & also since tail gating is dangerous how do you know if there wanting to overtake or they just happen to be similar speeds but may of had a better corner to take up the space? Since the whole day is based of consistence it would seem pretty stupid to be constantly slowing down to let others pass and then be slown down by them.
Edited by r_speedfreak_r
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
