  • Replies 78
Vic - what way from the city will you be going?
harbour tunnel onto gore hill freeway and then M2?
nfs - bags not racing you... :(
cool!see you there smoky!
nah more like down para road then onto the M4. ie. para in the arvo is freken peak hr mayhem. M4 is also.
So id have to leave early. Ill give you a call or something when im in side at the carpark.
Try and get the same lanes so I can drag yo ass :(
https://www.sau.com.au/forums/topic/136227-wsid/#findComment-2532559
How much does it suck that you are hoping for 4 runs. What a joke WSID are.
2wks ago a WSID official came around the pits/crowd looking for people to attend afew meetings with the WSID committee to discuss how WSID is run, what improvements can be made etc. I gave them my details for that straight away.
I figure seeing as though ive been to every wicked wednesday meeting that WSID have ever held (including the rained out meetings that were cancelled halfway through the night) and also all major weekend events and had more frozen hotdogs than I care to remember im sure their are some ideas/suggestions I could put forward to the committee.
So I guess no need to ask if i'll be there tonight because well.... im already there :P
https://www.sau.com.au/forums/topic/136227-wsid/#findComment-2532879
Tell them Wendy's charge too much :)
https://www.sau.com.au/forums/topic/136227-wsid/#findComment-2532973
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
