  • Replies 78
If I can get a 13.999999 I'd be stoked! I'll probably get low 14's though.
The GT Starlet should get pretty close to flat 13's though :happy: What about yourself? DO you know what time to expect? Send me a message when your down there if you want, i only work about 2 minutes away, I can hear the cars on trackdays from out the back of work!
https://www.sau.com.au/forums/topic/136227-wsid/page/3/#findComment-2552895
blew a f**king cooler pipe ;)
Been there, done that, know the feeling - better luck next time mate :mad:
On a brighter note, I managed to nail another 11 which was the aim of the night for me - 11.996 @ 115.50mph.
I'm a bit miffed about my mph though. It was consistently down around 115-116mph all night, whereas I was up around 118mph last time out :laugh:
Saw quite a few lines out there as well - fairly good night overall.
https://www.sau.com.au/forums/topic/136227-wsid/page/3/#findComment-2555115
next week and the week after and the week after!
car is in mechanics now.
got it back on but too scared to run again,
congrats on the time mitch for your first time out!
Craig - awesome - 13.6@102 :happy:
https://www.sau.com.au/forums/topic/136227-wsid/page/3/#findComment-2555731
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
