Ok, now that i have finally tracked down a Power FC for my R32 GTSt, i have a few questions.
Are the hand controllers universal, or are they specific to each model of ECU? If they are universal what $$$ should i expect to pay for a 2nd hand one?
Also the base maps that come supplied with the ECU, how close to the mark are they for a car running exhaust, filter, intercooler, and 0.85 bar boost. Maybe put in terms of whether it is better or worse then OE Nissan ECU. (Can i comfortably drive from A to B without harming engine???)
I know they still rely on the airflow meter, but i have heard people running vent to atmosphere BOVs with Power FCs. Do they still have the same prob with stalling, or does the flexibilty of the ECU allow you to tune around it??
... thats all the Qs i can think of for now
https://www.sau.com.au/forums/topic/13623-eureka-r32-gtst-power-fc/
I got a Power FC running in my HCR32
The part number for the hand controller is #FCC2NT010-00443
I pluged in my Power FC to give it a idle tune
10min standard idle, 10min with rear fog & 10min with aircon on.
I found out that the Power FC was tuned to the previous owner HCR32 which i dont know what exactly has been done to it so i resetted the Power FC, it ran ok i had the same setup as you did then also, i would just wait untill u can afford to tune the thing.
BOV is ok nothing happened, no stalling problem at all.
Hi guys, also have a Power FC in R32 RB20DET, we use the normal PFC Commander that works on Nissans, 415- N001. I have used this Commander on R32 GTR's, R33 GTR's, S13's and S14's. Plus it worked OK on the Honda and an RX7. I paid $300 for it, used, on the forum.
Hi Joe, that looks like a serial number not a part number.
Hi Roy, as with all Power FC's the default/base map is OK, it has very conservative fuel (too rich) and ignition (a bit retarded) maps to protect the engine. Apexi don't want to get sued. So there is no way the difference between Japanese 100 ron and Oz 98 ron is going to be a problem for a drive from home to the dyno shop.
We also vent the BOV to atmosphere, and the PFC is tuneable to over come the stalling problem.
Hope that helps.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
