[/b] Hi Guys,
My name's Kylee...This my first post on this fourm....Just got rid of my Vl which i had for over three years and decided I needed somethin a little newer and a bit quiker. So I bought a 94 R33 GTST and was just wondering if anyone can give me the correct specs of this make (Inc kw's). I was also curious to know whether or not they come standard with LSD, I have been told many different answers. Also, just wanted to know what the HICAS light means, I know what it stands for but it keeps comin up after i have driven the car for a while. I have been told its nothin to worry about and someone even mentioned theirs stays on the whole time cos they have a non standard computer? Anyway, my car is pretty much standard and I just had it dynoed and it has 158kw's so i was curious to know how many kw's they came out with :(
https://www.sau.com.au/forums/topic/136240-specs-of-a-r33-gtst/
they came with 184kw (manual gearbox). that is at the flywheel, not the wheels. any power figure quoted by a manufacturer is at the flywheel.
and yes they come standard with lsd, but there is 2 types of lsd. most have the standard viscous lsd. some have the active lsd.
Edited by mad082
should these questions have come before you bought the car?
No, because i would have bought the car anyway. I was just curious... having answered these questions before I bought the car would have been irrelavant. Knowing how many kw's they come standard with and if they have LSD would not have changed my mind about buying one.. things can always be changed on it anyway!
hi kylee,
um good question i was also after specs on mine stocko. I have simlar model to Yours. .. i found this in the forum. One of the guys here made it, (great work btw), check it out here. http://nissanskyline.6te.net/
got loads of info on skylines stock.. um i think they were 147rwkw stock btw.
cheers
Oh ps. Hicas light comming on. isnt normal. mine comes on occasionally, (hicas diagnostic mode) where light comes on and steering tightens.. but i disconnect battery for about 15 mins, then reconnect, and its ok. I think probably sensor issue. But No mechanics or performance shops ive been too so far can figure it out. so good luck with that one. but first think is to disconnect battery, hicas fuse, Hicas computer, and check all sensors. and clean connections. if u can find someone who knows how to troubleshoot the system properly. let me know. :P
Edited by silverbulletR33
187kw for series 2
and less than 184 for auto R33's
Thanks guys for the input.
The hicas still came on when i had the standard steering wheel though.
I now realise after looking at the other sites that i make the extra power at the wheels from standard because i have the exhaust upgrade. :)
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
