  • Replies 176
Posted Images
  • 3 weeks later...
  • 3 weeks later...
well pfc knock was going up to 220 ROFL!!!! we ended up finding that i have faulty knock sensor :S
Just completed a hicas swap to non-hicas rear cradle. undercarriage looks neat now - i will post up pics soon, still waiting for new adj rear toe arms to come in. So no more loose ball joints :ninja:
BIG THANKS TO 1400R and NICKO for helping with :) and KANSAI AUTOMOTIVE for hoist usage.
The car is getting a little more cosmetic work done very soon aswell :)
if you want to see video footage from G1 right click save target as. ***includes me / simon a31 / salad***
http://www.driftvideo.com.au/vids/2007_G1_Rnd1.wmv
here's a pic from G1 round 1 @ mallala raceway.
post-9092-1173448688.jpgpost-9092-1173448864.jpgpost-9092-1173448827.jpgpost-9092-1173448919.jpg
Edited by huddy
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
