hmmm well not much to report, but i'm back from Japan, and i have some new found inspiration from the DMAX ceffy!
also fitted
KTS traction rods
VS-ONE rear pillar brace
strobies in reverse lights
did a little more cleaning (FUN)
got tomei cam gears aswell and Gates racing timing belt to get fitted. Also got a couple other little things that will set the car off. New look coming in the next few months :)
  • 1 month later...
  • Replies 176
Posted Images
well new belt and cam gears fitted up, did G1 round 3 - good result qualifying in top 16 - drew christian pickering first round, he beat me 6-4, 6-4 on the two runs...
with only doing 2 rounds of the 3 round series, i ended up 16th for South Australia G1 Championships. ;)
The car is now gonna get pulled down again and freshened up... should look HOT!!!!
Also going to upgrade the turbo again (power hungry lol) so the hks gt2540 is now for sale - its been running on 1.2 bar at the moment (around 220rwkw). click link for details :thumbsup:
More updates later, as things start to happen
I've got some other bits for sale, and will update bits for sale as i find them. As i'm gonna do a shed clearout of all my bits and pieces.
Here's a pic from G1
  • 3 weeks later...
UPDATE
cars been pulled to pieces, new turbo should be here this week, gotta finish of sanding it all and then off it goes to get piping done and paint sprayed >_<
hoping for it to be done by the end of the year. you may or may NOT recognise it as the same car... lol. ;)
  • 1 month later...
well with help from my fellow FULL TUNE members, and SIMON from MORPOWA - i've been slowly getting this thing done.
there's 2 major mods going on at the moment, exterior and power.
only going to go into detail about the power side of it for now and unveil pics once car is all finished.
POWER
well the hks2540 is long gone, and 1400r sourced me a dmax manifold from japan which is now on the car. I also got myself a Garrett GT3076r IW with the .6 front and 56trim wheel with .63 exhaust housing from SIMON at MORPOWA he also modified the wastegate to have a larger port and also larger flap. Coming off the back of this is an awesome screamer dump / front pipe with flex join from AM PERFORMANCE here in Adelaide. I modified my intake pipe which i had on the previous setup to suit this turbo, its not perfect but it will be more than sufficient for the job.
still have to fit the nismo adjustable fuel pressure reg that i've got, but that is a simple bolt on item.
I am nearly at the point of starting the engine and hearing this thing run again, but i'm still waiting on the return of my I/C pipe modded, hose for oil drain - then all sorted.
260+ is the goal for this setup by what boost... now that is the question...but i will find out soon enough.
EXTERIOR
i have a 'few' more new things which will make the car stand out and make it more individual over other ceffy's, including other pieces from other cars which have been modified to suit... more on that when its all finished though!
i will put up a pic of how the car looks at the moment though.
cheers
-Matt
Edited by huddy
well paint colour should be revealed soon :thumbsup:
ultimately i would like 280+rwkw, but i do have gtr injectors with fuel reg, so unsure if i have enough fuel from this and also walbro intank pump.
also skeptical on the whole setup as its on a rb20 based engine.
should find out in the next month or so :D
  • 3 weeks later...
well... it runs!!
slight problem, need to modify the awesome front/dump as it is a little low :P
but other than that, it was good to start the engine in about 2months (or more)!!!
hopefully i'll get a tune next week, just have to get the dump/front modified again first.
got the GT3076r fitted up (with the wastegate ported out and larger flap fitted)
DMAX stainless manifold fitted (welded on extra gusset) (+ nissan ex mani gasket)
AM Performance Stainless screamer front/dump *TUFF AS*
new braided oil feed line and water lines, re-sleeved with heat sleeving
ally intake pipe was modified to suit with 4"-3" reducer
also fitted a nismo adjustable FPR
enjoy the pics.
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
