hmmm well not much to report, but i'm back from Japan, and i have some new found inspiration from the DMAX ceffy!
also fitted
KTS traction rods
VS-ONE rear pillar brace
strobies in reverse lights
did a little more cleaning (FUN)
got tomei cam gears aswell and Gates racing timing belt to get fitted. Also got a couple other little things that will set the car off. New look coming in the next few months :)
  • 1 month later...
  • Replies 176
Posted Images
well new belt and cam gears fitted up, did G1 round 3 - good result qualifying in top 16 - drew christian pickering first round, he beat me 6-4, 6-4 on the two runs...
with only doing 2 rounds of the 3 round series, i ended up 16th for South Australia G1 Championships. ;)
The car is now gonna get pulled down again and freshened up... should look HOT!!!!
Also going to upgrade the turbo again (power hungry lol) so the hks gt2540 is now for sale - its been running on 1.2 bar at the moment (around 220rwkw). click link for details :thumbsup:
More updates later, as things start to happen
I've got some other bits for sale, and will update bits for sale as i find them. As i'm gonna do a shed clearout of all my bits and pieces.
Here's a pic from G1
  • 3 weeks later...
UPDATE
cars been pulled to pieces, new turbo should be here this week, gotta finish of sanding it all and then off it goes to get piping done and paint sprayed >_<
hoping for it to be done by the end of the year. you may or may NOT recognise it as the same car... lol. ;)
  • 1 month later...
well with help from my fellow FULL TUNE members, and SIMON from MORPOWA - i've been slowly getting this thing done.
there's 2 major mods going on at the moment, exterior and power.
only going to go into detail about the power side of it for now and unveil pics once car is all finished.
POWER
well the hks2540 is long gone, and 1400r sourced me a dmax manifold from japan which is now on the car. I also got myself a Garrett GT3076r IW with the .6 front and 56trim wheel with .63 exhaust housing from SIMON at MORPOWA he also modified the wastegate to have a larger port and also larger flap. Coming off the back of this is an awesome screamer dump / front pipe with flex join from AM PERFORMANCE here in Adelaide. I modified my intake pipe which i had on the previous setup to suit this turbo, its not perfect but it will be more than sufficient for the job.
still have to fit the nismo adjustable fuel pressure reg that i've got, but that is a simple bolt on item.
I am nearly at the point of starting the engine and hearing this thing run again, but i'm still waiting on the return of my I/C pipe modded, hose for oil drain - then all sorted.
260+ is the goal for this setup by what boost... now that is the question...but i will find out soon enough.
EXTERIOR
i have a 'few' more new things which will make the car stand out and make it more individual over other ceffy's, including other pieces from other cars which have been modified to suit... more on that when its all finished though!
i will put up a pic of how the car looks at the moment though.
cheers
-Matt
Edited by huddy
well paint colour should be revealed soon :thumbsup:
ultimately i would like 280+rwkw, but i do have gtr injectors with fuel reg, so unsure if i have enough fuel from this and also walbro intank pump.
also skeptical on the whole setup as its on a rb20 based engine.
should find out in the next month or so :D
  • 3 weeks later...
well... it runs!!
slight problem, need to modify the awesome front/dump as it is a little low :P
but other than that, it was good to start the engine in about 2months (or more)!!!
hopefully i'll get a tune next week, just have to get the dump/front modified again first.
got the GT3076r fitted up (with the wastegate ported out and larger flap fitted)
DMAX stainless manifold fitted (welded on extra gusset) (+ nissan ex mani gasket)
AM Performance Stainless screamer front/dump *TUFF AS*
new braided oil feed line and water lines, re-sleeved with heat sleeving
ally intake pipe was modified to suit with 4"-3" reducer
also fitted a nismo adjustable FPR
enjoy the pics.
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
