  • Replies 176
Posted Images
  • 1 month later...
ok ok
so now got screamer pipe / ebc etc - engine all good 240rwkw
now got vented fibreglass bonnet from VIVA GARAGE
fibreglass spoiler - courtesy of VIVA GARAGE
letterbox grill
the 'other' type headlights
and swaybars come in this week - blade adjustables :)
large stickers removed :sick:
enjoy the pics
bonnet fitment was better than expected!
has a slight dip on one side but i know its not a show car, and dont really care lol...
WHITELINE SWAYBARS now fitted!!! even just driving home, HUGE difference to say the least! end links are both pretty much vertical also and didnt have too much trouble with fitting.
front is set on medium, rear on hard. (have to soften dampers rear)
yep all set for the 13th now :)!!! first practice in over a year!!!
i did end up going the 27mm and 22mm, i was surprised that the front that i pulled out was almost exactly the same thickness, although a lot lighter, and with driving a huge improvement with the new one.
rear was easily bigger than the one i pulled out, so i'm guessing that one was standard.
have to soften dampers in the rear, and i will see how it goes as is in the front :)
Your ceff is going better than ever Huddy, i was at the Drift Prac on Saturday wathcing and you were doing really well. How did you manage to pop a braided brake line though, thats a bit of a worry, as im looking into getting them for my ceff and i dont want them splitting on me :wub:
I recently bought a Whitelind adjustable 24mm front sway bar from a R32 GTSt and a rear GTR swaybar, i have only put the rear GTR one in so far but already the car feels much better and more "stable" through the hills. Their a great upgrade for the car considering the price.
huddy and simon were kicking ass at Mallala on the weekend.
Was really good to watch simons entries and huddy's into turn 1.
i believe the wheel was rubbing up against the braided line which caused it to split.
Correct me if im wrong Matt.
Will be out filming on the 10th next month.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
