Afternoon,
I need to order some ARP head studs and a timing belt, and I need them to go on air freight hopfully today. Does anyone know any dealers I can call that will have some in stock for an rb25 gtst?
Cheers,
Phee
Hi phee, you could try Performance Wholesale in QLD as they will have them in stock and would be able to arrange freight for you.
www.performancewholesale.com.au
Paul
yeh i give ya that one phee who would have thought in darwin lol did you get a new idler, tensioner and bolts.....i just ordered mine learnt i needed them last night lol
Edited by sinistagtst
Haha! I haven't learnt that one yet... god damn! I'll get the Gates belt tomorrow, and I just ordered my ARP head studs from www.performancewholesale.com.au - AWESOME service, very very helpful and I highly recommend them. The studs will be here tomorrow morning at 10am.
How much did those extra parts you needed come to Sinista?
Well they idler and tensioner come to bout $100 delivered from bearing industries (02) 96744322, parts numbers;
tensioner; NSK 60TB0732A
Idler; NSK 56TB2801B01
thats very cheap and new bolts washer etc were $15 from nissan
Ah that's not too bad... I was freaking thinking you were going to say a couple hundred. All rebuilds need those new parts?
Yeh i know i was in the same boat lol, yeh they do and make sure you get new bolts for $10-15 could save your engine big time, if one snaps then there goes your engine.
sinistagtst / phee.... doing the same to my engine at the moment.
is that new bolts for the idle and tensioner?
Will you be using new guides?
What else do you think should be changed when rebuilding an engine?
When i took it apart i found that many bolts were loose. Lucky nothing went bang!
I also don't want to skimp on a few $.
CURRENT LIST....
big and main bearings
clutch
forged pistons + rings
gtr rods
cam gears
cams (still to get)
02 sensor
injectors
full gasket set
afm
exhaust studs
exhaust
pfc
turbo (undecided)
Hey mate,
your list looks good, yes those bolts are for the idler and tensioner which you will also need. remember timing belt, do you want a thicker metal head gasket or are you just sticking with the standard one. other than that your list looks pretty good, and if you have the money you could do the turbo at the same time that way you save your self money by having to get your retuned when you blow the stock one up lol. what size injectors are you getting, whats your power figure in mind also what mods do you currently have.
sinistagtst.... not sure on the hg yet. what are you going with?
I'm after an 8.5 cr and am unsure whether or not to do some head work.
The injectors are 555 nismo's and i'm chasing around 280/300 rwkw.
I just saw thizzle's power/mods post and he is getting 300 with a gt-rs.
I've narrowed it down to a 2835 or gt30r. I think:)
Simon.
Hey mate,
Im goin with a 1.6mm or 1.8mm headgasket, im most likely using acl forged pistons which bring cr down to 8.4 but by the time i deck the head that will rise a bit and plus i want to run a fair bit of boost and most comments ive seen say that you can hardly notice the difference off boost with bringing the cr down. i would recomend the gt3040, the reason i say this is it will make power easier than the 2835, but you can choose your exhaust housing whether it be .63 or .8 for response. injectors for that power will be fine.
sinistagtst.... do you think the 3040 would be too big and laggy?
i read a post on th gt30r with the .63 exhaust housing and people couldn't get traction once it hit boost.
I was thinking about the gt30r with the .82 housing and am concerned about the lag issue.
Boost kicking in at 3700 revs or close to.
Wanting to drive mostly on the street with some track.
( big decision )
Simon
nope a 3040 would be fine if you dont mind a bit of lag go the .82 but if its response and more streetable go the .63 you will make power easier than the 2835 and you still have to put as much boost into it to make power compared to the smaller turbo, which you might also be close to the max power from the 2835.
dan
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
