On my R34 GTT, the discs were warped as I can feel intense vibration everytime I brake hard. After which I got the disc skimmed and slotted.
After a couple of weeks, the sympton re-appeared. it's not as bad as the first time but the steering vibrates whenever I brake hard. It's annoying me to the max and my mechanic says it's a common problem with Skylines. Is that so?
Does any of you experience the same thing?
https://www.sau.com.au/forums/topic/136263-warped-discs/
Not that common but I suspect it was not warped at all but has an area that had the brakes held on after a big stop getting the discs hot. Pad material migrates into the disc and the steel changes into a different form that is harder wearing, so as it wears a shudder appears. Time for new discs. Get RDA for good value.
https://www.sau.com.au/forums/topic/136263-warped-discs/#findComment-2534865
another thing is if you brake really hard from a decent speed, and stop and sit there for a few mins then the heat from the pads and rotors being so close and hot will warp that spot.
i had a similar problem on my old magna. i put new rotors on, after a while they got a bit warped. i got them machined, then after a month or 2 (not much heavy braking) it reapeared. ended up getting new rotors again and that solved it. it seemed to do 1 side more than the other. i think i may have also had a sticky piston that wasn't helping the problem.
https://www.sau.com.au/forums/topic/136263-warped-discs/#findComment-2535843
I got new pads after I machined the rotors. It performed well for a couple of weeks before the intense shuddering under hard braking re-occurs. It's irritating and does do to well with driving with confidence.
Someone mentioned it might not be the rotors BUT after I machine it, it works fine. Sigh.....
https://www.sau.com.au/forums/topic/136263-warped-discs/#findComment-2548677
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
