On my R34 GTT, the discs were warped as I can feel intense vibration everytime I brake hard. After which I got the disc skimmed and slotted.
After a couple of weeks, the sympton re-appeared. it's not as bad as the first time but the steering vibrates whenever I brake hard. It's annoying me to the max and my mechanic says it's a common problem with Skylines. Is that so?
Does any of you experience the same thing?
https://www.sau.com.au/forums/topic/136263-warped-discs/
Not that common but I suspect it was not warped at all but has an area that had the brakes held on after a big stop getting the discs hot. Pad material migrates into the disc and the steel changes into a different form that is harder wearing, so as it wears a shudder appears. Time for new discs. Get RDA for good value.
https://www.sau.com.au/forums/topic/136263-warped-discs/#findComment-2534865
another thing is if you brake really hard from a decent speed, and stop and sit there for a few mins then the heat from the pads and rotors being so close and hot will warp that spot.
i had a similar problem on my old magna. i put new rotors on, after a while they got a bit warped. i got them machined, then after a month or 2 (not much heavy braking) it reapeared. ended up getting new rotors again and that solved it. it seemed to do 1 side more than the other. i think i may have also had a sticky piston that wasn't helping the problem.
https://www.sau.com.au/forums/topic/136263-warped-discs/#findComment-2535843
I got new pads after I machined the rotors. It performed well for a couple of weeks before the intense shuddering under hard braking re-occurs. It's irritating and does do to well with driving with confidence.
Someone mentioned it might not be the rotors BUT after I machine it, it works fine. Sigh.....
https://www.sau.com.au/forums/topic/136263-warped-discs/#findComment-2548677
    • It sounds like the perfect time to do easier tasks like, work out how to pull the headlights fully apart, clean them inside and out, and make them meticulous... Or lose all the clips, f**k up polishing the lenses, and get frustrated with that job while you can't do bigger more fun ones and wind up with no usable headlights...   I mean... What?! 😛
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lipomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, more time to contemplate rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
