Hey guys,
Just a quick question.. i've got a greddy boost gauge that i suspect might have a fault. but i'm not too sure...
so my question is , should a boost gauge read zero when not it is not connected to anything at all. mine's currently sitting at 0.5 bar. yet when it is connected up, and idling it sits on zero - however the readings appear to be far too high (around 0.9bar when it should be 0.5-0.6bar).
any ideas?
cheers
Howie
when a boost guage isn't connected to anything at all it should read 0. obviously because there is no pressure going into it so there is nothing to read.
when idling, the guage should sit at bout -0.5 bar i think it is, or just below it. if it is sitting at 0 when the car is on and idling, then yes there is something wrong there
On idle you have manifold VACUUM.
If you Boost gauge starts its numbers at 0 then it should read 0 at idle!
If your gauge starts at - something it should read the idle vacuum, mine says about -20PSI (Mazda Familiar GTX)
Rev slightly and it goes from -20 to 0 then on to whatever boost I make when reving past 2000.
Thanks mate,
Well this is the model of the boost gauge in question. Guessing it should be a quarter way down from where it is there on idle and zero when not connected.
The pic shows where it would be with maybe 2000rpm or not connected.
It should be down much lower at idle but not sure at what number on your car.
I got the exact same gauge. It sits on 500mm (ie down the bottom) at idle.
You should have a little white box it connects to which should have a little knob (or equiv) you can adjust it with, either that or its on the back of the gauge. I didn't install mine so I'm not sure exactly where it is
Thanks heaps guys. Just having a chat to satanic just then, and he's theory seems to fit in best, the face plate may have rotated when i put the gauge in the a-pillar (it was a bitch to fit in and i was grabbing and twisting the hell out of the thing).
I'll check it out again tonight. Cheers again guys most helpful bunch over at sau.
Hi a mate had a autometer boost gauge and it showed 2 psi up, but in the instructions It tells you to undo a screw to set in back to 0 they do this because to the pressure when transport e.g., plane and the difference in other countries.
interesting... my mech oil temp gauge sits at 60degrees unless it gets hotter.. so let me know how u fixed it so i can adjust mine also >_<
also my water temp doesnt work at all :O and YES i connected it up properly lol
got full exhaust??
If so, then the boost will increase slightly..
Got boost controller of any sort?? Then maybe it has been boosted..
first things first. is it a mechanical guage or electric? ie. does it run a vacuum line to the back of the gauge?
if it's mechanical it should read "0" when car is switched off, or gauge is not connected. if it's electric it should just fall to the 6 oclock position.
the mechanical gauges have a bourbon tube in them, these can get damage and it tends to happen when they have been removed/replaced. was the guage new or second hand? the face does not rotate so it would not have moved during your installation into the a pillar. sadly if it is damaged it's most likely a throw away.
Gidday guys,
Yep it's a mechanical - has a turbo/split dump pipe, but the restriction's in the rest of the system. No boost controller, so no way it'd be running 0.9bar.
I think i'll have to adjust it like you say.
let you know how i go.
i have a spare mech boost guage (splitfire) that was reading -10 when disconnected.
i pulled it apart, not easy as it was not meant to be opened, and there's a weight on a coiled spring that moves thru pressure entering the nipple.
if you can get it open, move that weight around slightly with ur finger, and you will see the needle sitting at different spots. once u get it to zero, it should be good to go.
Just having a look, this ain't gonna be easy to open. I'll need some sort of special tool to take the special bolts off at the end of each of those threads. But i'll see if i can do it with a few mobile phone toolsets.
Thanks again.
is there anyway you can take the glass/rim off the front? that's how i did mine.
taking those bolts out wont help, not on mine anyway.
i bent the bezel lip slightly and slipped the rim off. then undo that bolt around the nipple(where the hose goes), and the face comes out in one piece.
I didnt really care if i broke it or not, coz it was a spare, but it works now.
keep in mind, that's how mine opened/worked. i'm not familiar with yours, i'm just assuming that they all work the same.
I started taking it out from the front, then scratched it and thought to myself I really should exhaust all other options first. Anyhow it'll probably be binned or relegated to a playstation cabinet if it's not fixed.
Edit : Thinking about it logically, it must be assembled from the front in the factory, so naturally you'd think it'd come out from the front also.
Edited by Howie
Na, it's no trouble. Have done it several times now.
Got pics for you here with some explanations.
If you can find another way, or other advice, try it. Coz you will damage the bezel getting it off, but try keep the damage to the back so you dont see it.
Ignore the duct tape in the first pic, that's just to hold it in it's cup tightly, not a result from taking it apart, lol.
Edited by Munkyb0y
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
