Hi,
Im getting a rattling noise at night either in my engine bay or my dash. I can only hear the noise when the boost kicks in and the rattling sounds faster with the more revs the car does.
It sounds like either -
The engine is rattling,
Turbo is rattling,
Dash is rattling.
Im really not sure, sometimes the noise comes from the left side which is where the turbo is and sometimes it comes from the middle. The noise doesnt usally happen in the day but every now and then it does. It also seems that the noise only appears when the car is warm. When im driving the car for the first 5mins or so i cannot hear anything but then once the car is warm it starts to make a noise.
Could it be that once the engine bay is warm my Pod is sucking in Heat and casuing Detonation?
Or that something is loose in my turbo? but noise doesnt happen all the time..
Or that the inside of dash is really loose and im getting random noises?
My mods are:
3 - 1/2 inch Cat back
R34 Turbo - Running on 12psi
Lighten Flywheel
K&N Air Filter Pod
FMIC
Any Ideas or Help would be great!!!
Edited by r32matt
https://www.sau.com.au/forums/topic/136280-rattling-from-engine-or-turbo/
Hope its not what I had happen to my RB20 -sounds similar - Big ends 3&5, found rear oil pump screws nearly all out after strip down.
Ignored fluctuating oil press guage as sender fault that is common, but my oil pressure was screwed most of the time.
Get your oil pressure checked...
My oil pressue gauge was sitting around the 4 mark but after I put in new Oil the pressure gauge has dropped alot and without acceleration the pressure is really low on the gauge. I just thought the pressure dropped becasue I put in Fully Synthetic Oil. hmmmm
It is probably pretty obvious but I noticed on my car the cover for the fuses inside the engine bay was not on exactly perfect so when vibrations got higher in the engine bay it made a noise which drove me crazy, another noise which occassionally comes on is on the gear knob, cause its an auto the actuall button you press in when wanting to change gears is a little loose when vibrations come into the car or on bumpy rds.
Drew.
Ok, so I took my car for a drive last night. When cold it was driving fine, nothing wrong. Once it heated up a noise started coming from the engine. So im thinking now that its not my dash. The noise comes on during boost (3000revs) but if i put my foot down the noise or rattling goes away at around 5000revs and up. But if i dont put my foot down i can hear the rattling sound up to high revs. Ive reved out my car all the way to 5000 revs without letting the turbo kick in and the motor made no noise at all. Plus the motor sounds fine when idling. Sounds like the rattling starts off slow and then with the more revs it gets quicker until u cannot hear it becasue either the engine is getting to loud or the rattling is going so fast that i cant hear it anymore. During the day today everything was fine, it was reving out beautiful with no noise at all. So im thinking that maybe my turbo is loose but that doesnt explain why its only happening during the night. Sounds so crap at night and so smooth in the day. Could it be a loose turbo or is there another reason for what is happening?
All help would be great!!!
Thanks
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
