Hey guys.
Ok so ive established that the Justjap JJR intercoolers are good and worth the money ($550 for a type 2 kit)
My goal is:
FMIC + Exhaust then crank up the boost.
Good idea?
OK lets say it is :laugh:
I completed my tax return today, should be getting about $900.
Car is almost stock, except for a POD and BOV.
My Dillema is, do I go for the exhaust or Intercooler or something else.
Can only afford one at this time.
The Exhaust i had my eye on was the X-Force 3.5" Turbo Back system ($799 for mld steel, $950 for stainless steel)
The Intercooler kit im also looking at is the JJR Type 2 Intercooler kit.
So if I could get peoples thoughts on:
*Zorst, FMIC or other
*What effects will each have on my car
*Any other sugestions you feel are relevant
Thanks guys :kiss:
https://www.sau.com.au/forums/topic/136284-dilema/
Whats this split dump buisness? (don't know what that means :laugh: )
Also would there be much difference between a 3" and a 3.5" system?
X-Force does both the 3" and 3.5" turbo back.
Im thinking X-Force mainly because I had an X-Force cat back on my previous car and it sounded great.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2534076
do a search on split dump pipe and you will see... the split dump seperates the wastegate gas then rejoins about 40cm down the dump... makes big difference to a single bell dump..
i wouldn't go anything bigger then 3" on the exhaust... unless ur running twin turbo or have 400+rw/kw
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535035
good way to spend $900 in my opinion:
- full turbo-back exhaust
- turbotech boost controller set to about 10psi
- oil and sparkies changed
- 1 hour on dyno to adjust the timing
you want a 3" exhaust.. no bigger, no smaller...
probalby the greatest mod that one could EVER do to a turbocharged vehicle...
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535060
turbo back exhaust, then front mount followed by boost and then powerfc it to get maxium bang for buck - but its gonna cost more than 900
Edit: X-force has a nice rumble to it, depends on what you want - quiet or loud.
Edited by emsta2003
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535127
I want loud...ish.
As in, legal and not overly droney.
Does anyone know if the X-Force has this split dump that was mentioned? If not, any other reccomendations on a full turbo back system for $900 or less.
Also is it worth paying more for stainless steel? Ive heard mild steel is more than fine for many years.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535767
you can get the split dump front from batmbl (hes a member on these forums), and then just get the cat back from x-force and attach it to whatever cat you got running
thats going to work out much more expensive than the full x-force kit, and not give much of a power difference.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536089
Ok well theres the Xforce turbo back
$799 for Mild Steel
$950 for Stainless steel
Theres also the JJR Split dump for $125
Whats the difference between a 'front pipe' and a 'dump pipe' ??
Does a split dump make a big difference?
Again what sort of difference would I notice going from stock to the full Xforce turbo back
And what difference ontop of that would I notice if there was a split dump?
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536131
no you wouldn't notice the difference between a split dump and a bell mouth dump.
the dump pipe is the pipe off the turbo. the front pipe goes from the dump pipe to the turbo. the x-force pipe is a 1 piece pipe. it has both in the front pipe.
the jjr dump pipe also requires a front pipe.
Edited by mad082
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536294
how can you dyno tune a stock ecu though? didn't think there would be much gain to be had.
i didn't sasy "dyno tune" i said time on the dyno to adjust timing
a dyno is just rollers so that the car can be driven as on the street but still monitored (eg listening for pinging)
with the car strapped to the dyno the mechanic can see how the engine runs (eg is it making the right amount of power?) and adjust the CAS to change the base timing (give it more power!)
this usually costs around $100-110 depending on the workshop and is highly recommended
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2537336
i agree with mad082. get an x-force turbo back system, get a bleed valve and set it to 8-9psi, maybe even 10. the standard side mount shud support this, but if u want to be more safe and economical, buy a gtt side mount. after this u shud pick up at least 20-30kws at the wheels
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2537999
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
