Harris Engine Services
12 Ilma St Bankstown NSW 2200
ph: (02) 9771 3432 Engine Reconditioning
Harris Engine Service Pty Ltd
Unit 2/ 80 Milperra Rd Revesby 2212 (02) 9771 3068
Probably the first one.
Edited by Lithius
  • 4 weeks later...
i had a gti-r motor built there.
i can say the build and everything was fine! no complaints
but he supplied me with non genuine seals and gaskets.. my first nightmare!! all leaked and gave me head sore as a gtir motor is a c**t in and out.
if i had supplied genuine kit everything would have been good!
when someone sees gti-r they think sr20.
similar but coompletely different rule applies here!
  • 2 months later...
  • 2 years later...
old topic but has anyone had recent work done with these guys?
seems pretty reasonably priced for rb25 bottom end rebuild w forged pistons rod and headwork...
i had 1 cyl lose comp and it looks pretty minor with just the honing visibly defective via bore scope,
i called around and basically no on wants to listen to a know it all...
i was after two quotes one with just engine supplied and one full car with engine in lace trying to save some dollars if i can,
on first contact the best people to speak with were harris engine service and c&v everyone else (DART, Autosports, CRD) basically werent interested in what i had to say and said they do it there way and thats it...
i was very happy with the initial quote i recieved from H.E.S. thus now i would like to know of a few experiences some of yous may have had in the past/present...
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
