thanks for all the input guys. Damage was done on piston no. 1. He is a qualified mechanic and has prevously worked at a high performance workshop. He has has had many cars thats he has worked on enter numerous car shows. I dont know why, but he must of cranked it over many times as the valve looks like its been chewed up and spit out! He must of had the timing belt on when he cranked it over otherwise there would be more then one damaged valve. But i was not there to see. How could the valve seat dislodge itself in the 1st place? Cause that is also what he has stated. Hard to tell coz there was pretty much no valve seat left! Other then the broken valve, would anything else in the vavle train need to be replaced? Someone mentioned retainer? Also i have heard that the rods are GTR. Would the force and stress have damaged or weaken it in any way? My friend said that i may need the rod resize which also means a balance bottom end! ouch!
I will take this as an oppurtunity to rebulid my engine with forgies etc. Since the block needs to be honed, i will get oversized forgies (40 thou),
new big end bearings and rod and main bearings. Along with a thicker gasket ( 1.2mm ), heavy duty valve springs and head studs. Any other suggestions and advice/feedback would be greatly appreciated. i have a GCG highflow and NOS kit both still in their boxes along with all other supporting mods. As the GCG maxs out at around 260rwkw ( what a shame coz the engine package can handle way more! ) ive decided to make the most out of my NOS. Love it or hate it boys!!! Any idea as to the max jet size i can run providing the clutch is up tio scratch?
Valve seats don't just pop out, or disappear. Get the fragments and photograph them clearly on the broken surfaces.
Rods should not need a resize unless the bearings have spun and damaged the journals. Get them x-rayed though for cracks. Costs about $20. You would balance it while it is apart. Again, doesn't cost much but doing all the right things adds up. Also get the crank checked for straightness.
I don't see the need for a 1.2mm gasket for the low power you will be running. It will just hurt engine response. Use a stock gasket and O ring the block. Same with valve springs (unless you are using a big big cam) and studs. They are not a normal point of failure on engines running upwards of 300 rwkw and I assume the NOS is just a 50hp shot, so unless you have plans of a big kW engine they will be just bragging goodies.
Forgies are pretty well mandatory in RB25s but I think the Neo is a bit better built considering only a few ringland issues recorded, plus they come stock with GTR spec rods. The head stuff is unecessary unless wanting to rev beyond 8000-8500 regularly and even then the valves will be a limiting factor, as well as the hydraulic buckets. Just putting into perspective why you would need to install such items. I'm all for a completely tuff engine, but only if you will actually use the expensive items.
Damn. I wanted to be the one to tell you that. hehe.
I smashed my ringlands.
With NOS if you are running a lot of it you need pistons with bigger clearances and make sure you have good quality headstuds. How much are we talking? I'd hate to have to drill for bigger head studs.
Also you mention valve springs but not cams. :happy: Tomei type B Poncams work with stock valve train. I don't think you should go any bigger with that turbo. You might like bronze valve guides but for the money I don't think they are worth it unless the aforementioned hit of nos is really big.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
