thanks for all the input guys. Damage was done on piston no. 1. He is a qualified mechanic and has prevously worked at a high performance workshop. He has has had many cars thats he has worked on enter numerous car shows. I dont know why, but he must of cranked it over many times as the valve looks like its been chewed up and spit out! He must of had the timing belt on when he cranked it over otherwise there would be more then one damaged valve. But i was not there to see. How could the valve seat dislodge itself in the 1st place? Cause that is also what he has stated. Hard to tell coz there was pretty much no valve seat left! Other then the broken valve, would anything else in the vavle train need to be replaced? Someone mentioned retainer? Also i have heard that the rods are GTR. Would the force and stress have damaged or weaken it in any way? My friend said that i may need the rod resize which also means a balance bottom end! ouch!
I will take this as an oppurtunity to rebulid my engine with forgies etc. Since the block needs to be honed, i will get oversized forgies (40 thou),
new big end bearings and rod and main bearings. Along with a thicker gasket ( 1.2mm ), heavy duty valve springs and head studs. Any other suggestions and advice/feedback would be greatly appreciated. i have a GCG highflow and NOS kit both still in their boxes along with all other supporting mods. As the GCG maxs out at around 260rwkw ( what a shame coz the engine package can handle way more! ) ive decided to make the most out of my NOS. Love it or hate it boys!!! Any idea as to the max jet size i can run providing the clutch is up tio scratch?
Valve seats don't just pop out, or disappear. Get the fragments and photograph them clearly on the broken surfaces.
Rods should not need a resize unless the bearings have spun and damaged the journals. Get them x-rayed though for cracks. Costs about $20. You would balance it while it is apart. Again, doesn't cost much but doing all the right things adds up. Also get the crank checked for straightness.
I don't see the need for a 1.2mm gasket for the low power you will be running. It will just hurt engine response. Use a stock gasket and O ring the block. Same with valve springs (unless you are using a big big cam) and studs. They are not a normal point of failure on engines running upwards of 300 rwkw and I assume the NOS is just a 50hp shot, so unless you have plans of a big kW engine they will be just bragging goodies.
Forgies are pretty well mandatory in RB25s but I think the Neo is a bit better built considering only a few ringland issues recorded, plus they come stock with GTR spec rods. The head stuff is unecessary unless wanting to rev beyond 8000-8500 regularly and even then the valves will be a limiting factor, as well as the hydraulic buckets. Just putting into perspective why you would need to install such items. I'm all for a completely tuff engine, but only if you will actually use the expensive items.
Damn. I wanted to be the one to tell you that. hehe.
I smashed my ringlands.
With NOS if you are running a lot of it you need pistons with bigger clearances and make sure you have good quality headstuds. How much are we talking? I'd hate to have to drill for bigger head studs.
Also you mention valve springs but not cams. :happy: Tomei type B Poncams work with stock valve train. I don't think you should go any bigger with that turbo. You might like bronze valve guides but for the money I don't think they are worth it unless the aforementioned hit of nos is really big.
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
