Good saving Dan.
Just of note:
I didn't bother with the bolts and idlers after trying to order through Nissan (they required chassis no. etc). Spoke to their mechanics and parts people - they said they never bother replacing if they look in good condition. You can see if the thread looks bad. Unless they come loose then they shouldn't be subject to load anywhere near there tensile or endurance limit.
They have failed in the past. Bl4ck32's went soon after the cam belt was replaced, the bolt simply sheared off. Maybe it was overtightened... who knows. :)
Go to a different nissan that deals with the imports regulary, here in Adelaide both Main North and Grand Nissan rarely require chassis numbers.
Ben the thread can look just fine, but won't reveal if a fatigue failure is propogating.
Just go to an engineering materials supplier and tell them you need a high grade item of 8.8 minimum and take the old ones as samples.
process for removing the stud from the block ..
anyone got a nice easy way to do it ?
Well i welded a bolt onto it and then used a wrench, but that's mainly cause i snapped the threaded bit on the end off, whoops.
Other option is two bolts, screw them both and and lock them together then do as above.
Also multigrips work sometimes
Replaced both with bolts, best place i found was a local that deals with truck and tractor spares, plenty of high grade bolts!
Edited by Rudager
sweet, thought o the welding option, wanted to see if there was an easier way ..
Quick question about the same thing... Just called:
Bearing Industries
Seven Hills Rd (cnr Station Rd) Seven Hills 2147
(02) 9674 4322
And and Idler and Tensioner is going to cost me $101.20 incl GST and freight. The catch is they only post through Aust Post, which means it is going to take a week to get here (Darwin) and my engine is going to be put back in the car Monday week. Is the Idler, Tensioner and Gates Belt one of the last things to go onto the engine?
Does anyone have any suggestions on how to get this gear up here sooner???
LOL @ Darwin shipping. Lived there a couple of years and always got the week to 6 weeks line on delivery from down south. :yes:
Funny that overnight is still overnight though......although I've had a lock bar take 2 weeks 40 km across Melbourne.
Troy, aren't all RB tensioners and idlers the same?
Want able to confirm it. So needing the car back on the road and runnign ASAP for the rally i just got one thru Nissan...only to run out of time and didnt change them...so they sit in a box. So will compare, anyone want to pay me $220 for mine before i check? ;)
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
