  • Replies 50
I'll be at SCS... :D
it's gonna be hot again! So bring your sunscreen !
Btw, have they confirmed a new location for SCS 2006 yet?
Edited by Howie
....Btw, have they confirmed a new location for SCS 2006 yet?
Vmax had the launch for the event last night. Ive posted a link to it in the SCS EOI thread
http://www.skylinesaustralia.com/forums/in...howtopic=131372
Morphetville Racecourse it is then ! Thanks mate.
Edit: Double post
Doesn't seem they're having the Hillclimb this year as part of SCS, instead Drifts & burnout comp at Mallala.
ah damn, i was hoping they would do the hillclimb event again. ill most likely head out to mallala as a spectator :dry:
is anyone going to the hillclimb trials on oct2? I just put in my entry form. its only for new commers who haven't raced there before.
would like to but didnt much like the looks of the track ... how much was it
link to website or related material to which i can complete an entry form as well. any specific license required? i.e. CAMS?
edit* doh! i think its too late to ask that now, its on monday. where is it?
Edited by Nozila
cams about $20 for a 1 day license? btw where is the hillsclimb trails? a website would be great so i dont need to ask alot of questions...if you know it ;)
edite* no needs, its on cams website
Edited by Nozila
first time i went to Collingrove the track didnt look nothing like this
the grass was a foot high and if u speared off looked like there were rocks in the midle of the wall
on a side note u need to buy tags and there $100
EDIT on further reading the tags can be hired and or bought back by SCC
@ 1/2 orriginal cost ... read on
http://www.sportingcarclubsa.org.au/Portal...RFID%20Form.pdf
Edited by Madaz
boys as stated earlier the cams licence can be purchased on the day for most events.
you dont have to purchase the timing tags for the trials, im just seeing if its worth entering in the actual championship.
actual competition is on the 14th-15th of october.
should be a good day.
hey guys, didnt see anyone there.
was about 35 cars, and a great time had by all.
luckily no-one went off the track, as some of us were pushing it hard.
05 WRX STI 37.58 top time i think, Toyota MR2 38.xx i think and i ended up with 3 under 40's with 39.58 being my best.
im looking at entering the SA Championships on the 14th and 15th, but want to get a boost controller and fuel pump upgrade done to boost it up a little.
anyone keen on lending me a hand?
i can offer signage on the vehicle for the day, and ill also fix you up for your time.
let me know guys asap.
regards,
luke
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
