my car made 182rwkw stock.
the dyno operator had no idea what he was doing, but tried to tell me that 'you never know whats under the heatshield'...
'yeah, i do...its stock'
didnt even have an exhaust
  • Replies 113
Posted Images
lol if you're refferring to me, im the first to admit my car DOES NOT have 182rwkw stock. has a full 3" exhaust and 9psi atm, and it still wouldnt make that much power.
Notice it was run in 3rd gear also...
the operator clearly f**ked it up, and wasted my money.
Anyway, that was ages ago. I was pissed off because I was dynoing it to see what it made bone stock, so that when i added mods i could see the increase for each...but that went out the window.
Car will be going to ray at RE on tuesday (if my PFC arrives tomorrow) for a tune.
3" exhaust
fmic
040
pfc
MBC
will be dynoed before and after ;)
lol don't take it as a dig it was just an observation of what may have bumped the figure up slightly. Which I'm sure you noticed also. :O
Regarding 3rd to 4th gear.. Mine actually made 4rwkw in 4th.
Quite interested to see how the before after run goes, would be interesting if the power level stock is still up around 180rwkw. lol ;)
lol don't take it as a dig it was just an observation of what may have bumped the figure up slightly. Which I'm sure you noticed also. ;)
Quite interested to see how the before after run goes, would be interesting if the power level stock is still up around 180rwkw. lol :O
I didnt take it as a dig :(
I threw that dyno sheet out a long time ago. No stock R33 GTS-T makes 182rwkw ;)
and if my car had 182rwkw back then, in theory it'd have 190+ now that i have an exhaust...and if my car has 190rwkw, then i'll sell it and buy something fast....lol
on tuesday i'm hoping for around 160rwkw as it is (the 040 will be installed before any dynoing :bunny:) and hoping for around 200rwkw after the tune and boost upped to probably 12psi..
but will be happy with more midrange rather than just a big max power, and thats exactly what Ray has told me he'll focus on :laugh:
lol you were running a stock exh. with that run. lmao.. I missed that little part in your previous post. :O
yep. 100% stock!
not stock + anything....just stock
was so funny when he was like
'you never know whats under the heatshield in these things'
'the dyno doesn't lie'
'yeah i do. its stock...'
'no, but if you dont know how to use it....'
Ehh dezz, if ur getting a powerfc would it be ok if i borrowed ur stock ECU to test my car. If its ok, jus leave it with Ray and say it is for Tas,
Would be much appreciated but its ok if u dont want to.
Good luck on Tuesday regardless dude, I reckon with ur mods u'll get 175 - 180rwkw. Next mod for u should def be dump/front pipe, preferably with a split.
I would lend it to you if I didn't live so far from RE. Its gonna be close to an hour drive for me, so I won't be back there anytime soon...
And i'm going for a lot more than 180rwkw....more around the 200rwkw mark.
As I already mentioned, my car has a full 3" turbo back, including a split front/dump...
i dont see a major problem with IT being 55.
to me its more realistic if anything.
if you were to place a temp probe under the bonnett, then this would be the realistic values you would see. so IT really comes down to how the car is setup, ie: unshielded pod, it will certainly suck in mega hot air, so 55 is acceptable. if its the stock airbox and snorkel then i guess placing the sensor at the opening of the snorkel would give the best result, i dont think 55 is correct for the opening of the snorkle.
did u see where he placed the airtemp sensor dezz?
But infating power figures because of a poorly setup induction system is wrong and doesnt reflect real world performance. The dyno will read higher but real world performance will be down. Is that really the way to go about correcting power figures?
Maybe airtemp entering the grill correction will reflect a real world power figure.
the temp sensor was put inside the intake pipe, at the second last rubber joiner before the plenum.
He was telling me how he puts it there because it gives the ACTUAL intake temp, as its taken just before the air gets into the plenum, and not just how cold the air is when its blown into the snorkel...
That was before he actually dynoed it...so it was sounding like he knew what he was doing...I guess I found out otherwise soon after :(
yeah that makes sense (to me at least) putting the air temp sensor after intercooler to measure air going into the plenum. the gtr ecu (and PFC) do this and base correction around that value.
to me it make sense to correct up the power readings for higher intake temps, as this is the typical results you would see on the street.
the problem is much more obvious when you see an unshieled pop setup make 200rwkw as the bonnet is open, the airtemp sensor is right next to the AT sensor on the crossover bar next to the dyno computer and both IT and AT are the same, or 1 deg apart. in normal conditions on the street, it wont make that power, as its sucking in hot air.
hang on, higher IT, adds or takes away power?
On the street higher IT = less power.
On the dyno higher IT = more power.
I have the IT sensor placed inside my airbox and airtemps are 0-1degree's what the AMB temp is. BUT I do run a CAI.
How the turbo heats the air and how well the FMIC cools the air back down is then setup dependant and will reflect in real world performance. IF I were to run no intercooler I could in theory still be making the same power on the dyno but real world acceleration would suck.
If the dyno operator is reading the post turbo 'real' inlet temps and having the dyno correct a power figure on this then that is simply way off. The motors 'real' Power will always be down as the engine will always be swallowing air of such a temp.
What will we have next.. Boost correction, compression ratio correction, engine displacement correction? :(
AMB air temp correction all the way.
i think a large number of dyno sheets have incorrect IT and AT
out of all the ones i have looked at, i dont remember seeing many that have it correctly. one would always expect IT to be higher than AT, just not sure how much. i dont think any of my sheets have IT and AT correct
I suppose if they're all going to be 'wrong' then as long as they are all wrong in the same way with similar differences....
Mine may have had the more accurate intake temp, but something else was clearly f**ked up. Or maybe the higher intake temp on my dyno, while more accurate, is what caused the ridiculous figure?
So maybe its not the right way to do it...
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
