So if those cars with high inlet temps were to pull up next to another car with low inlet temps but same power on the dyno down at the local drag stip which will accelerate and run down the 1/4 quicker? My bet is the one with the low IT temps. But the power figures are the same. wtf. :(
Or think of it this way... Same car same car identical power curves at the same km/h, ones a turbo 6 ones a v8. The turbo 6 has had some pretty funky correction on its power curve due to its higher inlet temps. Which one will run down the 1/4 quicker? The N/A with its lower IT temps.
  • Replies 113
Posted Images
yep, common sense would say the 3rd one has the wrong IT :(
I'm thinking it was something else done wrong that gave such a massive power figure on mine (for a stock 33), so hopefully results similar to the norm can be acheived with the more accurate IT temp, so long as everything else is done correctly
tiz all too confusing to me
I'll just be happy to see a result that is 'normal' when compared to everyone elses with similar mods...ie paul, justin, and paradizzle all have similar mods (except para with the safc instead of the pfc) and are all around the 190-210rwkw mark :(
ramp rate (RR) being different will also alter the output figure.
higher ramp rate means the dyno pulls the car harder on the rollers, this can affect how the engine comes on boost, as more load means more boost. also the shootout mode can correct the figures accordingly
SHOOT4
SHOOT4F
SHOOT6
SHOOT6F
SHOOT8
SHOOTF
and so on, the F being forced induction turbo or supercharged.
so if your car was done in say SHOOT6 then you will get different results if you did your car in SHOOT6F and so on
At the last boostworx dyno day it was shown that the lesser shootout modes read slightly lower than the higher I.e Shoot4 vs Shoot81.
Looking through all the dyno sheets they are all within 5degree's of the AMB temp. I watched shaun place the IT sensor either in the cai snorkle or basically on the pod. HOWEVER.. Dyno runs were done with the bonnet up. So not really reflecting what would really occur on the street.
The way I see it is that if the IT is more than 10C higher than the AT, there is going be some good amount of correction involved. Infact that 'bogus' sheet shown before with similar AT/IT, thats the figures that would involve the least amount of SAE correction and thus a more 'real' result IMO. Anyone can get the temp sensor, throw it near the turbo manifold and get some bullshit results.
Before this thread gets hijacked ive got an update for those interested.
Took my car back to RE customs today to check it out again. We discovered the following. The timing on the car had been set to full advanced. The confusing part however was that the car was still running ok.
The problem is most likely to be either the timing belt was put on incorrectly and is out by a knob by my previous mechanic or the knock sensor is faulty or the wrong model.
Anyway, we reset the timing and moved it back a bit and we did another run on the dyno. For those of u non-believes the car still made 190rwkW and the AFR this time were areound 12.75. We did altogether 6 runs and the car did not ping or knock on any of the runs (altho i have been using octane booster lately)
Gonna take it back to Ray sometime next week to sort out the timing issue and if the timing belt has been installed incorrectly i am gonna lose it at my previous mechanic. At the end of the day however, i am basically driving around a 190rwkW basically stock skyline.... I guess it proves that the RB motor is one of the best responding motors to modification.
Your not running an adj. cam gear? This will throw the positioning of the cas sensor out.
Maybe the incorrectly set cam timing has helped power a tad. :wave:
Wouldn't it suck if you dropped it back to find its lost power everywhere and back to the norm.
How did it respond to modification if its stock?
Still dont see how 190rwkw is possible...its not really.
Did you check the ECU
Maybe the incorrectly set cam timing has helped power a tad. :P
Nah its got stock cam gears... and yes it would suck :P ut i'd rather be safe than sorry
Its not completely stock, just lightly modded. Yea i checked the ECU it doesnt look like its remapped, i havent checked the inside of it yet. I reckon the timing is causing it to have this much power tho.
I dont see it possible either. See how it goes once all its little issues are sorted out (cam timing and afr).
If it still pulls high figures on stock boost then..................... get a run on a different dyno and if its still a high figure.............. well there's no explaination. :P
But you said you reset the timing and it still made 190...so it can't be the advanced timing...
You wouldn't be able to tell from the outside of the ECU if its been changed at all...
Maybe get a dyno run on another dyno just to see what that comes up with...or take it to the drags and see what mph you get...someone on here could work out rough power based on mph
hehe, i wasn't questioning the dyno or the operator...shit, im going there tomorrow so that wouldn't be a wise choice if i dont have faith in the workshop...
Just saying that in this case, its not a normal situation, so another dyno is just another option to get some ideas...chances are it will get a similar figure on the other dyno, then he can start crossing other shit off the list :P
Yea, atm i dont really care about the power figure, dont get me wrong, I'm like really happy, (less than $1000 spent and ive got 190rwkW) but im more worried bout the AFR. I reckon once that is fixed it'll go back down to 180... which is still pretty good for my mods, and not that unusual.
Dezz post up ur results when u get ur run 2moro. Good luck for getting 200rwkW, i will be very interested to see - my car has basically the same mods as u minus powerFC which I will hopefully be getting before Xmas.
IT & AT should be relatively the same for a turbo car
the DD "correction" is way off. The massive possible changed between cooler setups, boost levels/turbo efficiency etc can never be allowed for by some "software"
Remember the I/C will cool the charge, if its 55, its gonna be lower by the time it reaches the motor.
Closer to ambient is best
cheers
I'm still going to call botched figures.
Skylines simply don't make alomst 200rwkw standard.
As I said before, when my car was stock, it was in perfect condition, and by that I mean perfect. Motor was 169psi across all cylinders and 2% leakdown which is on par to brand new.
Made 140rwkw with 10psi and a full exhaust and FMIC.
210rwkw with powerfc added and 13psi boost, and toluene.
Dyno Dynamics Dyno.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
