  • Replies 113
Posted Images
I Just got my NEO dyno'd,
I got 179rwkw with a catback and apexi filter.
The heatsoak was pretty bad, the next run after that I only got 164.
From the mods you have it's possible.
Cheers
Josh
Yea exactly and mine was staying on 13 the whole time. The other guy was saying that if it was the fuel pump the AFR would keep rising... I don't see how tho
i think you are right there. i'd say its probably the fuel pressure regulator.
mayb i should just replace the FPR 1st and see if it fixes it
Should i be getting any particular brand or just get a stock1?
nismo ones are cheap and well tested .. and just fit inplace of the stock one easily
Depends on your long term goals.
If you don't plan to throw a highflow on it just grab another cheap (if they are cheap that is) stock item from a wreckers and try.
Otherwise.. grab a nismo item. They work well and are well priced. Grab one from nengun/perfectrun and the like.
You can't just throw a FPR onto a stock ECU. It'll mess up the fueling on anything but full throttle.
Also AFRs at 13 wouldn't be responsible for the high power. The power difference say between 12 and 13 might only be 2-5% max. 196rwkw at 8.5psi.. sounds like an RB30 haha.
what i find odd is that the AFRs are almost dead flat all the way through, even though it is lean
maybe its not actually a stock ECU? have you checked what it looks like for some kind of sticker? or opened it even?
Nah havent checked it, i jus assumed it was stock i guess. I'll do that this weekend and let u guys know. ECU is located under passenger side kick panel right?
yeah but if anything that would make the figures more realistic..
its when IT is way higher than AT that you see higher figures, so with the values around the same the computer won't apply much (any?) correction...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
