Hello ,
I thought you guys might be intrested in my little dragrace project
I modified a 92 ..R32 GTS N/A 2,0
i built a VERY modified RB26Dett N1 Engine
gearbox is Chevy TH400 drag auto
rear axle is a short Ford 9" with fourlink
rear wheels are Centerline rims with M&T 31" Slicks
front wheels are Moroso frontrunners on modified original rims
Engine/gearbox is moved backwards 38 cm for better chassi reactions
Drysump system, full rollcage
and much much more ..............
i can specify in detail ,if someone is interested.....
https://www.sau.com.au/forums/topic/136356-r32-gts-dragrace/
Im interested :D post up detailed specs, times, dyno sheets and anything else you have this thing looks like an insane project.
Did you have much trouble adapting that box to the engine?
Who and how did you engineer and fit in the shortened 9inch, can we get pics?
And also please spec your suspension setup :mellow:
hehehe if you can be bothered of course... thanks.
PS. Im assuming Minitubbed at the very least...?
Edited by benigno
Adapting the gearbox to the Engine was not easy,
First we had to make a adapterplate for the engine/gearbox
after that we had to make an adapter for the 8"Turbine/ Skyline
auto flexplate, and last we made a adapter that centered the turbine
in the crankshaft
Me and my friends made everything on the car
i have no detail pics of the 9inch ,but i can get it for you and write
in detail what we have done with the rear
i have double adjustable Aldan Drag shocks
and custom springs on the car at the moment
we have a homepage where you can see some more pics
of the car
go to www.Maxoutperformance.se
at the top click on "projekt"
next click on the red text that says " KLICKA HÄR FÖR MER BILDER"
the latest pics....
to see the older building pics
at the top of page click on the red text that says "kLICKA HÄR FÖR ÄLDRE BILDER"
the site will soon com in English......
Nissan RB26 DETT N1 Engine
concrete filled engine block to prevent the block from cracking at high outputs ( they do crack ,trust me)
Modified carillo rods
Modified JE pistons
external electric waterpump
6 individual waterinlets for each cylinder
with crossflowing watersystem
special modified oilsystem in engine block
Modified Moroso drysump system with custom drysump
from Chevy Big block dragrace Engine
Custom steel crank
Custom inlet manifold
90 mm Trottle
Bosch 1600cc injectors
Special custom made camshafts
custom made valves ,springs,seats,
Modified Garret GT42 R BB Turbocharger
3 Bosch motorsport fuelpumps
Engine runs on Alcohol
Gearbox is, Chevy Th 400 modified for dragracing
Modified gear pattern
Transbreak
all internal parts are modified or changed
8" Turbine with 6000 rpm stallspeed
B&M dural aluminum covers
Shortened Ford 9" rear axle 4,88 ratio
double adjustable Aldan drag shocks
with custom springs
fullfloat 35 splined axles
drag spec four link
Full Pro mod roll cage
and much more ....i will write in more soon
Edited by Maxout
What is hidden by MSPAINT.EXE ............hmmmmmm did not think that anyone would notice that...
well there are things that i simply dont mention about the engine and car. because it took me alot of time .money and hard work to come up with a solution that gets rid of some difficult problems
this is one of those things. so i had to cover it because i wanted to show the trunk.
i thought you might ask about some other thing wich is not hidden in this pic.....
Edited by Maxout
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
