R33 Gtst Carbon Fibre Door Sills - Now Ready!
Hi all,
As you may or may not know; I am doing a group buy on assorted fibreglass and carbon fibre bits from a supplier I've found overseas. Stuff is of top quality and looks awesome; only downside is that they do not mass produce, nor do they advertise. However, on that note - it means you end up with something unique that you can boldly say only a handful of other people in the world will have.
Anyways, have a look here for more information:
http://www.skylinesaustralia.com/forums/in...howtopic=133286
and
http://www.skylinesaustralia.com/forums/in...howtopic=133336
Now many people have asked if the CF Door Sills can be made for the R33GTST and initially the answer was no - until now. I've been begging them so much that they are designing the moulds required to make the R33GTST sills :dry:
Price has been confirmed to be $270.00 per set + Freight (which will be dependent on the size of the order). So all of you who want to get your hands on these unique items; stick your hands up - I can assure you that you won't get them from anywhere else :(
CONFIRMED INTEREST:
2) syd33
3) babia
4) Malecki (prototype) [ 100% Confirmed ]
5) Suspense [ OUT ]
6) bilbo117
9) skyline33t
11) pkblade
12) mitchy_
14) LBR33
16) halz [ 100% Confirmed ]
18) steveo_r33 [ 100% Confirmed ]
CONFIRMED PAYMENTS:
15) KummaZ [ DELIVERED ]
10) croat [ DELIVERED ]
13) thizzle [ DELIVERED ]
8) R3LOAD [ DELIVERED ]
22) Mavric [ DELIVERED ]
7) R33_Phreak [ DELIVERED ]
19) Ol_mate [ DELIVERED ]
1) Nebz [ PAYMENT CONFIRMED ]
17) hayden49 [ PAYMENT CONFIRMED ]
20) halz [ PAYMENT CONFIRMED ]
21) filecon [ PAYMENT CONFIRMED ]
  • Replies 171
Posted Images
syd33 added to list;
Also; if you are interested in other CF bits; have a look on the other thread... at the moment there is only R33 CAI headlight which is only to be used for drag/track.
Answer to question 1: No
Answer to question 2: Maybe, I'll have to break their balls for an answer though :(
NB: I'm getting these R33 sills made from scratch; prototype has already been offered to Malecki - they will be the first CF Sills to be produce for the R33 in the world to my knowledge :D
Guest
