Yeah 3.0 twin turbo direct injected - VR30DDTT. Makes 298kw factory (or 400hp if you prefer). Compared to the 32 GTR which makes 250kw at the wheels in production car trim it should be in mid pack somewhere despite weighing 1700kg.
By IXMandalorianXI · Posted
Thank you for the heads up! Will definitely take a look! -
Hi all, My 1990 R32 GT-R has developed a bad knocking sound coming from the what I assume is the front differential (the reason why I assume this is when I pull the fuse for the asetta the knock disappears put it back in and it comes back and yes the transfer case and gearbox has fresh oil in it), the uni joint on the front differential side was broken bad it would have been causing massive vibrations into the pinion gear, has anyone experienced this before? And is anyone selling a front differential Center complete with pinion and crown gear ? For the drive shaft I can’t find any driveline workshops in SE QLD that will put a new uni joint on the front prop shaft as they are a staked uni joint no one wants to touch it 😭 does anyone have any recommendations on any workshops that can replace the uni joint ? sorry if this has been posted before I couldn’t find anything using the search function for this exact issue thank you NSM32 sorry for the bad photo, yes it’s missing a bolt I took the photo while removing the shaft to take to a workshop to try and get it repaired
By hardsteppa · Posted
The offset of the wheel is usually stamped on the inside of the rim. So just pull the wheel off and see if it's marked as such. -
It's very possible my measurements are wrong as I did measure with the wheel and tire still on the car. It's possible I didn't judge inner gap correctly and ended up adding width. I'm eager to buy new wheels, but I think I might be putting the cart before the horse. The best thing to do this right. I can take off the wheels off, I might even just have the tires taken off and do some proper measurements. It won't cost me much, if anything, and will save me a whole bunch of headache in the long run.
