R33 Gtst Carbon Fibre Door Sills - Now Ready!
Hi all,
As you may or may not know; I am doing a group buy on assorted fibreglass and carbon fibre bits from a supplier I've found overseas. Stuff is of top quality and looks awesome; only downside is that they do not mass produce, nor do they advertise. However, on that note - it means you end up with something unique that you can boldly say only a handful of other people in the world will have.
Anyways, have a look here for more information:
http://www.skylinesaustralia.com/forums/in...howtopic=133286
and
http://www.skylinesaustralia.com/forums/in...howtopic=133336
Now many people have asked if the CF Door Sills can be made for the R33GTST and initially the answer was no - until now. I've been begging them so much that they are designing the moulds required to make the R33GTST sills :dry:
Price has been confirmed to be $270.00 per set + Freight (which will be dependent on the size of the order). So all of you who want to get your hands on these unique items; stick your hands up - I can assure you that you won't get them from anywhere else :(
CONFIRMED INTEREST:
2) syd33
3) babia
4) Malecki (prototype) [ 100% Confirmed ]
5) Suspense [ OUT ]
6) bilbo117
9) skyline33t
11) pkblade
12) mitchy_
14) LBR33
16) halz [ 100% Confirmed ]
18) steveo_r33 [ 100% Confirmed ]
CONFIRMED PAYMENTS:
15) KummaZ [ DELIVERED ]
10) croat [ DELIVERED ]
13) thizzle [ DELIVERED ]
8) R3LOAD [ DELIVERED ]
22) Mavric [ DELIVERED ]
7) R33_Phreak [ DELIVERED ]
19) Ol_mate [ DELIVERED ]
1) Nebz [ PAYMENT CONFIRMED ]
17) hayden49 [ PAYMENT CONFIRMED ]
20) halz [ PAYMENT CONFIRMED ]
21) filecon [ PAYMENT CONFIRMED ]
  • Replies 171
Posted Images
syd33 added to list;
Also; if you are interested in other CF bits; have a look on the other thread... at the moment there is only R33 CAI headlight which is only to be used for drag/track.
Answer to question 1: No
Answer to question 2: Maybe, I'll have to break their balls for an answer though :(
NB: I'm getting these R33 sills made from scratch; prototype has already been offered to Malecki - they will be the first CF Sills to be produce for the R33 in the world to my knowledge :D
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
